Question about Ricoh Aficio 2016 Black and White Copier
When I do copies on my copier RICOH Aficio 2016, I have black lines on my copies. How to resolve this problem?
Ploz change opc durm and blade kindly check you opc durm u find black circul on both side its mean u need to replace OPC durm .
Posted on Jan 02, 2013
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Repair and service manual for Ricoh Aficio 250
Check with this website, they should be able to get you one
http://www.service-manual.net/ashop/catalogue.php?exp=&cat=283&gclid=COzWt96Ym5QCFSUqagodnl83tg
Posted on Jun 30, 2008
angelus316
  • 41 Answers
SOURCE: Ricoh Aficio MP 6000 copier with error code SC555
there is no sc 555 on those machines only sc 550 and that relates to what is called a fuser web.It does need to be changed but you can reset it by pressing the following in order
1- yellow clear key
2- number 1
3- number 0
4- number 7
5- press and hold down the orange clear/stop key for 5-10 seconds.
the screen changes
select copy sp
select sp 1
scroll down to SP1902 001 and select
reset that value to 0 and select enter
switch machine off and on and that should get you going for now.
Let me know
Posted on May 28, 2009
SOURCE: Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Posted on Dec 07, 2009
M2Tech1
  • 313 Answers
SOURCE: How do I clean or replace the drum on a Ricoh
The drum unit on these models is a complete replacement unit. the drum can only be cleaned by removing the unit and then there are some screws to be taken out. two on the back plat and two on the front. if you take these cover plates of the unit will split and you can remove the drum(Blue roller) and under neath there is a charge roller as well that can be cleaned.. only use water on the black cahrge roller and gently rub with a cloth till clean. The drum with a very soft cloth and some liquid brasso may clean it up or get rid of the scratch lines but if they are too worn the drum needs replacing. you can clean the scanner glass and the mirrors underneath here as well.B0392201 is the part number for the Drum unit which comes as a complete unit. you may need to purchase the developer for the drum init as well B0399640 is the part number for this. hope this helps >>>A
Posted on Feb 10, 2010
Testimonial: "Thank you this is helpful"
Why Ricoh aficio 2016 asking for toner when toner is full
please check that the toner unit is not choke with toner,
again, check if the toner motor is rotating,
also check if the buttom of the toner unit is designed to fit the toner motor.
finally check the td sensor .
this may be the major cuase of this problem.
good luck.
Jul 16, 2014 | Ricoh Aficio 2016 Black and White Copier
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Black spots on paper - Ricoh Aficio MP2000
If it uses a cartridge, check for leaks. If a leak is found, there may be toner scattered inside the copier
Oct 11, 2012 | Ricoh Aficio MP 2000 Black and White...
I have ricoh aficio mp 2000, it's photocopy print black lining
if it background like faint toner all over copy need to replace developer powder/drum/blade/gears
Oct 08, 2011 | Ricoh Aficio MP 2000 Black and White...
My aficio richo 2016 black and white copier is showing code error sc 544. pls how do i fix this problem.
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
May 11, 2011 | Ricoh Aficio 2016 Black and White Copier
I'm getting black lines when I print or copy on my Ricoh Aficio 3228C. It looks like they're caused by the rollers. Does anyone know how I can clean or resolve this issue?
looke my friend black lines have many reasons on of various reasons rollers in fusing unit may be scratched if it like that use marker black pen and put pen in spots of scratch area sconde reason pcr primary charge roller and scanner filter
Feb 09, 2011 | Ricoh Office Equipment & Supplies
Power not on copier aficio 2016
more detailes please tell me what happened
Jan 16, 2011 | Ricoh Aficio 2016 Black and White Copier
My Ricoh Aficio 1013f has 16,000 copies on it. It
Ask the service agent, what the maintance cycle of the model is. Sound like it needs a periodic service.
This being the drum and some rollers. this will resolve the squeak as well
Good Luck
Mar 03, 2010 | Ricoh Aficio 1013F Copier
Ricoh Aficio 2016 Black and White Copier Logo
130 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
