Question about LG Xnote Ed500 Laptop Lcd Screen 15.4" Wxga Ccfl Single
How to avoid "press f1 to continue" when I start my computer
    New Friend:
Change your HDD
Posted on Jan 02, 2013
  • paragr17
    paragr17 Jan 02, 2013
    i tried this but still i m facing..i have also change the CMOS BATTERY...
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
Logical drive has been disabled due to possible data loss
Replace the HDD whose led is blinking in AMBER ( orange ) colour.
Mar 11, 2012 | HP Compaq ProLiant DL380 G4 Server
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
SMART FAILURE PREDICTED ON HARD DISK 2 TOSHIBA MK2035GSS (S1) PRESS F1 TO CONTINUE. ON START UP COMPUTER GOES TO THIS SCREEN EVERY OPTION ON START UP OF F1 DOES NOT START WINDOWS AND COMPUTER RETURNS TO...
Unfortunately it sounds like Your hard drive has gone bad. If this is the Hard Drive that contains your operating system you would have to replace Hard Drive and then replace Operating system using your Restore cd's.
Jul 11, 2011 | Computers & Internet
When I start my computer, I'll get a black screen with a bunch of text with "American Megatrends" as the header. The screen is unusual, and on the bottom it says "CPU fan error!, press F1 to...
You need to plug in your CPU fan. The CPU fan is VERY important in that it constantly cools your processor, making sure your computer doesn't over heat. If the computer runs and the fan isn't running, the CPU will over heat and cost you hundreds of dollars.
Turn off the power Unplug your computer Open up the case of your computer Find your CPU fan Find the cord coming from it Find the plug on your motherboard labeled CPU fan Plug it in there Plug your computer back in Turn it on
Mar 17, 2011 | iBuyPower Gamer Extreme 573D3 Phenom II X4...
When i start the computer not bootup befor few days its working fine but when i start the computer its need always press f1 to continue i replace the cmos battery but still problem same but now a days its...
while computer starts before pressing f1 key press del key... you will go into the bios of *********** board... you can change these alert settings there... you will have an option that says wait for F1... select NO to that option and save the settings and exit from bios...
Aug 04, 2010 | AMD ASUS A7N8X-VM/400 Motherboard
Computer fix
i had same problem last week i ended up having to use a recovery disk to format my hd ... i also had the boot sector write message it came up after a while of pressing f1
Oct 26, 2009 | Computers & Internet
ML530 Startup
Check your Hardware configuration.  This usually happens when you tell the system BIOS that you have for example, a second floppy or Hard Drive, when you do not.  So it stops and asks you what to do next.
Hope that helps.
Eddyfix
Oct 12, 2007 | HP Compaq ProLiant ML530 Server
LG Xnote Ed500 Laptop Lcd Screen 15.4" Wxga Ccfl Single Logo
26 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
