Question about Maytag Neptune MDE5500AY Electric Dryer
Display pad off
The display pad is completely off, and nothing happens when I press any button, including start. I just used it the other day with no problem, but now it just won't work at all. I tried unplugging it and re-plugging in but that didn't do anything.
  • classydancer Nov 17, 2007
    I have turned the circut breaker off and back on with no change in the pad. The pad reads 8.8. no matter what button is pushed it doesn't change. I have tried closing and opening the door several times and push the off key nothing, tried putting wet clothes in the tub nothing, tried spinning the tub nothing. HELP
CHECK TO SEE IF THE OUTLIT WORKS COULD BE THE FUSE
Posted on Jul 20, 2007
SOURCE:
How can I get self clean to start?
To Self-Clean Using AUTO-CLEAN
1. Press AUTO CLEAN.
2. Press the HOUR and MIN "up" or "down" arrow pads to set the desired self-clean cycle time.
3. Press START. The oven door will automatically lock. "CLn," "LOCKED," "ON," "CLEAN," the Cooktop Lockout icon, and the time remaining will be displayed.
4. When the self-clean cycle is complete "END" will be displayed, and "PUSH"/"OFF" will blink alternately.
5. Press OFF/CANCEL. "LOCKED," "END," and the Cooktop Lockout icon will disappear from the display. "PUSH"/"OFF" will stop blinking, and clock will show the time of day.
6. Once the oven is completely cooled, remove ash with a damp cloth.
I hope this helps and thank you for a model number that made this possible for me to assist you. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 05, 2016 | Whirlpool GS563LXSS - stainless Steel Gas...
Help me with my Frigidaire Es510 Control Self cleaning,Oven with deep well style cooktop It has the time flashing but will not respond and it also has PF on it
The CLOCK pad is used to set the clock. The clock may beset for 12 or 24 hour time of day operation. The clock has beenpreset at the factory for the 12 hour operation. When the range isfirst plugged in, or when the power supply to the range has beeninterrupted, the timer in the display will flash with power failure "PF"
Instructions:
To set the clock (example below for 1:30):1. Press the round "CLOCK" button. "CLO" will appear in the display (Fig. 2).2. Press the round "1" "3" "0" pads to set the time of day to 1:30 (Fig. 3)."CLO" will appear in the display. Press the round "Start" button. "CLO" willdisappear and the clock will start (Fig. 4).
Oct 10, 2011 | Kitchen Ranges
My child locked the microwave pad. How do I unlock it?
The operation manual is available for free download from Samsung at this site: http://downloadcenter.samsung.com/content/UM/200305/20030529145700437_MW5592.pdf
The answer to how to lock and unlock is on page 15 of the manual. It's instructions are: 1. Press the '0' button, the display will show: "PRESS 1- DEMO 2-CHILD LOCK"
2. Press the "2" button, the display will show: "PRESS START"
3. Press the start button and the display will show "LOCK" then returns to the time of day.
At this point the microwave can't be used. To unlock, just repeat steps 1-3.
Hope this helps
Jun 18, 2011 | Samsung MW5592W Microwave Oven
I have a Health O Meter HDM560. I need to reset the #1 and #2 users and start over, can you help me there is nothing in the manual about it I can find.
Current Instruction Manual for the HDM560 can be found here:
http://www.healthometer.com/Manuals/MANUALS/HDM560-05_43_41816518.PDF
For resetting it would be similar to the initial setting process. FOLLOW these steps:
Lift display cover. Push "SET" button at bottom of pad. User "1" and "2" will appear.
User "1" will start blinking. Press the "USER" button to choose user "1" or "2". Once selected, press "SET" button to lock in information.
Both "HEIGHT" and "AGE" will appear on the screen. The "HEIGHT" will start blinking. Press the "UP" or "DOWN" arrows to find the correct height.
After entering height, press the "AGE" button. Use the "UP" and "DOWN" arrows to enter correct age and press "SET".
Both "MALE" and "FEMALE" images will be displayed. Press the "GENDER" button until the correct MALE/FEMALE image blinks and then press "SET". This will lock in the information.
Your correct information including User, Height, Age, and Gender will be displayed. Now you are ready to calculate weight.
Tap your person "USER" number (1 or 2) in center of scale with your toe. Your personal profile will appear. Wait until "000" appears. Stand on scale so bare feet are positioned over silver pad surface. "000" will blink your weight for approximately 3 seconds. "BF" will flash and body fat percentage will appear. The scale will turn off automatically in a few seconds.
May 21, 2011 | Health-O-Meter Health & Beauty
How do I change date and time?
Step 1 Press the FEATURE key followed by **8463 Step 2 Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options: Step 3 Select CHANGE - the display will show the following options: Step 4 Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. Step 5 After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same. If you want to change the date, select NEXT. Step 6 The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005). Select NEXT, and repeat to change the month and the day. Step 7 Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 30, 2011 | Nortel Norstar 16-Line PBX Speakerphone
Hi , i have tried what you mention for hb88rc let say i am doing the programing and it is currently 10 am. (example) i want it to be on at 7am and off at 7pm for the entire week i do as the instruction...
You happened to catch the same guy that answered before.
Lets go through the exact programming steps:
Your schedule is ON at 7am and Off at 7pm ALL week.
1) Set the clock to current time:
Hold down clock button while doing next steps
Press Hour button until correct Hour am-pm shows (10:00am for example)
Press MIN button until correct minute shows.
>>> Now wait, the manual seems to leave off a step here... it doesn't say to enter current day.
OK, lets make sure current day is set.
I guess you press Day button until current day shows.
Now release the clock button.
2) Program the timer to your schedule:
Press and release PROG button.
press it once and Program1 ON is ready to be programmed
The screen looks like the picture below:
3) Ready to set Program1 ON:
The display shows the number 1 and it shows the word ON.
Press DAY button as many times as it takes until all days show at top of display.
Press Hour button until 7 am shows in display
Double check that the time is AM
Press MIN button until :00 shows in display
4) ON time for Program1 is set
We are ready to set OFF time for Program1.
5) Press the PROG button until the display shows Program1 OFF just like photo below
Notice that the number 1 and the word OFF appear on display
6) Ready to set Program1 OFF
Press Hour button until 7 pm shows in display
Double check that the time is PM
OFF time for Program1 is set
7) Programming is complete, and we are ready to use the timer
(If you want more programs, press PROG button until program2 ON shows in display)
8) To exit programming, press the CLOCK button.
Current time show in the display.
The timer should be operating correctly now.
Add a comment, if you want to contact me directly.
Nov 09, 2010 | Intermatic HB88RC - 7-Day Programmable...
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
How to change time on my T7316E Nortel phone
Step 1
Password Retry Step 2
Hour: 01 Next Change Step 3
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
Minutes: 00 Next Change Step 6
Year: 99 Next Change Step 7
Mar 11, 2009 | Lands Phones
Daylight saving time
1. Press CLOCK pad. Indicator word TIME
will flash in the display.
2. Press the appropriate number pads for
the current time. (Time is in a 12-hour
format.)
time
Mar 13, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Neptune MDE5500AY Electric Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
