Question about Beko 24 in. D3731F Free-standing Dishwasher
No power in my beko dishwasher - Beko 24 in. D3731F Free-standing Dishwasher
  • Beko Master
  • 3,247 Answers
This could be due to the thermal fuse having tripped or the controller becoming faulty. This needs to be replaced.
I am assuming you have turned the input mains power to dishwasher off and back on.
Posted on Jan 02, 2013
  • 1 more comment
  • joy maclean Jan 02, 2013
    have changed fuse, there are no lights coming on the control panel
    where is the thermal fuse located
  • Sam Jan 03, 2013
    please refer to this sitehttp://www.buyspares.co.uk/beko/dishwash... I am suspecting either part 6802 or 6920. Either of these could have caused the trip. Unless of course the on/off switch is itself faulty. The site gives access to part locations for door and main body.
  • Beko Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Beko dishwasher DSFN1534B shorts and arcs when you open the door. Electrician says it is dangerous. Just over one year old.
Yes very dangerous turn off the power contact makes hotline this maybe under warranty.
May 15, 2017 | Beko Dishwashers
Have a beko dishwasher dwd5411w water not getting into machine
Type "Beko dishwasher problems" into your search engine, and you will find websites that will help you.
God bless your efforts.
Oct 27, 2016 | Beko Dishwashers
Why beko dishwasher wont fill with water
Assuming you can select programs and start it, the most likely problem is water inlet valve. Make sure the water tap under kitchen sink is open.
The water inlet valve looks like this.
Beko DS1054S Solenoid Valve
Sep 03, 2014 | Beko DS1054S 450 mm Silver Freestanding...
On Off switch faulty
The switch is available from eSpares.
http://www.espares.co.uk/product/es1624719/onoff-switch?ModelId=1630729
The rear of the control panel will become accessible by removing the screws holding the stainless steel door panel from inside the door. Make sure the dishwasher is disconnected from the mains power supply.
Mar 30, 2014 | Beko Dishwashers
No power to beko 1530 dishwasher
first make sure that power is coming in by checking connection with multimeter.If there is power coming to where it is wired up then the problem maybe the handle swtich either burned out or not making connection when the door is closed
Jan 29, 2012 | Beko Dishwashers
I've bought the Beko dishwasher without an instruction manual. Can I get one?
Try this link,
http://fiftyeggs.blob.core.windows.net/bekoupload/manuals/DE2541FW.pdf
Jan 23, 2012 | Beko DE2541FW 18 in. Portable Dishwasher
We are a retirement association who can't use our dishwasher as there is no instruction book HELP please
I have done a long search and the manuals I can locate for Beko diswashers are here:
http://www.retrevo.com/samples/Beko-manuals.html
and here:
http://www.beko.co.uk/Manuals.aspx
Use this link and then go to the right side search panel and search for full sized dishwashers. (9 models)
I reommend you use this link below and ask if they can provide you with a manual.
Beko Customer Support
http://www.beko.co.uk/Contactus.aspx
I did not find the D3421FS as an exact match.
images?q=tbn:and9gcroxhdxl1uym3gjptjmamvwbrjwfucsrt88rvwupqjtgazmzmnx1mt9kg
Thanks for choosing FixYa,
Kelly
Mar 25, 2011 | Dishwashers
Beko 4310 stopped mid wash and no sign of any power. have checked fuse and mains, no problem... machine just over 1 year old... any ideas?
I am assuming it is a beko dwd4310 dishwasher.
If the display has totally blanked off then the control board has packed up.
You can find the part at this site.
Nov 07, 2010 | Beko Dishwashers
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko 24 in. D3731F Free-standing Dishwasher Logo
306 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
