Question about Dehumidifiers
During the winter i find it hard to breathe i live in the basement in a small room and often wake up coughing what should i do?
    Sergeant:
  • 475 Answers
You maybe should look into buying a air purifier that might help you and your cough.
Posted on Jan 02, 2013
    Scholar:
  • 45 Answers
Inhalation of Clorox fumes is not something you would want to do willingly. However, there are situations where you will smell this chemical's fumes. Brief encounters should not cause harm. The product, however, should be used with caution. Inhaling the Clorox fumes can cause physical problems.
Read more: Heating
Posted on Dec 20, 2013
Just purchased this product and we are having difficulty figuring out the best setting so that the unit will shut off and on. It seems to only run continious. The model no. is VK0025000CURNPF735A0794 ...
When a humidifier is first placed into service depending on the environment you placed it in, it can take up to a week to actually shut off.
Think about this...
Q? Why did you buy the unit in the first place?
Ans. Area you want to use it in is damp.
So the NEW humidifier has to really work hard to remove moisture from everything in the space.
Furiniture, structure to include cement floors and walls. This can take a very very long time initially. If there is a sump pump in the basement the humidifier needs to be placed quite a distance from the sump area. If the structure foundation and walls are allowing water seepage into the basement it may NEVER shut off.
If it does not shut off after several days. Move the unit to a small room upstairs that you can place it in and close the door just to test to see if the unit will cycle on and off. If it cycles on and off in a small room you may want to inspect your basement foundation and check for plumbing problems.
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Whirlpool 25-Pint Dehumidifier
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
Apr 28, 2011 | Goldstar DH304 Dehumidifier
MODEL DM 162EBS. Why is it when I switch my dehumidfier on 10 minutes later it goes to defrost. [ WHY?]
Let's think thru the dehumidification process--
A dehumidifer needs to create a COLD surface, on which to condense the moisture in the room.
If your room is quite cool, it is esily possible that the COLD surface can go below freezing-- Now the water is trapped in the ice-- So-- it has to defrost, to melt off the ice, and start all over again!
Can you move the Dehumidifier to a warmer spot-- maybe near a radiator, or a heat register? -- You will remove much more moisture in that way, too..
Just a question: Most homes are WAY TO DRY during the winter months-- are you sure you need to dehumidify your living area? (Maybe you are drying the basement?-- or a wet area?)
Just seeing if I can help
Mack B
Jan 20, 2011 | Dehumidifiers
Does dehuidifiers stop working as hard in the winter months then in the summer months. Because my water bucket has not fill up since gotten cold. I live is Alexandria Va and it is winter here.
Generally speaking there is more moisture in the air during the summer months. As the humidity goes down in the winter your dehumidifier will not collect as much water because there is less moisture in the air.
Dec 28, 2010 | Haier DM30EAL Dehumidifier
My Soleus Dehumidifer is not dehumidifying
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Soleus CFM-40 Dehumidifier
Have a wind chaser wdh running in my basement and it keeps icing
Dec 29, 2009 | Windchaser WDH928 Dehumidifier
Why would it not take water out of the air, it runs so long it creates ice on the outside of it. With no water in the bucket. its in the Basement its 52 degrees and the humidie is 84. what can i do to...
Room must be above 60.
Dec 28, 2009 | Whirlpool AD50J Dehumidifier
Have Whirlpool AD50USS - unit ran for over 24 hours in DRY mode but collected no water. Should have been water in bucket as basement smells musty.
Dec 28, 2009 | Whirlpool Dehumidifiers
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
My humidifier is leaking inside. i notice there is a small tubeoutside the bucket and not connected to nothing so it leaks out.what should i do?
Dec 09, 2009 | DeLonghi DE500 Dehumidifier
Dehumidifiers Logo
166 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
