ENGLISH MANUAL FOR BALAY PROFESSIONAL 504 3HB504B
3 Suggested Answers
  • 353 Answers
SOURCE: Looking for a User Manual in English for 2 Balay
aSK ON gOOGLE
Posted on Aug 11, 2010
e-Guru
  • 3917 Answers
SOURCE: I would like the User/Operating
Hi
Please check this link regarding your query :-
https://www.2instructions.com/search.php?cmarque=BALAY&modele=TS%2050100
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 14, 2010
Balay oven manual 3h506 in English
Try Googling (balay)(3h506)(manual) without parens.
Mar 24, 2018 | In Microwave Ovens
I need a manual in english for BALAY ELECTRONIC TS6010?
Hello, I think this link might help you--found it on another techie website, http://ww2.justanswer.com/uploads/SM/smitty1486/2013-07-06_161710_balay_3tw64560a.pdf
Aug 21, 2015 | Washing Machines
I need dishwasher instructions in english for a balay.
If you send me an email to LBrown18062@hotmail.com, I will send you the manual that I have. I do not believe that Balay puts out a specific manual, but the one that I have is in english.
Mar 26, 2012 | Dishwashers
Where can i get user istructions for balay te755 washing machine in english
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 05, 2011 | GE Washing Machines
I have bought a Balay Electric Oven 3HB 516XP and the user manual is in Spanish how can I get an English one.
http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM
Pick the one that says EN to download
Mar 03, 2011 | Ovens
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
