Question about Nikon Coolpix 5700 Digital Camera
Poor picture quality on screen
When i take a picture the of the resulting image on the screen is very poor - look like lots of line going across the screen with the subject in the background. the screen itself is ok since previous pictures look fine when recalled.
    Genius:
  • 2,985 Answers
This is an incipient CCD problem -will probably get worse over time. Kikon support Team is the first place to try the model may be subject to recall If it is not or out of warranty- replacing the camera is the next option- there is not generally an economic repair option.
Posted on Jun 25, 2007
SOURCE:
Replacement screen
Does the resulting video or photos show the dots? Do some test shots and transfer them to computer to view. If the dots are not in the resulting images or videos, then the LCD is going bad but still usable. If the dots are in the images, it needs service repairs.
May 30, 2013 | JVC Everio GZ-MG130 Camcorder
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
Feb 13, 2010 | HP LaserJet 4650 Color Printer
D100 overall yellowish colors poor image quality
White balance has a lot to do with image results. You need to set it for your subject shooting conditions
Jun 09, 2008 | Nikon D100 Digital Camera
Blue lines running through my image
Did u use the original ink cartridges or compatible ones or refilled?
Jan 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Dec 02, 2007 | Proscan PS32500 32" TV
NO SCREEN FOR TAKING PICS
same problem. I actually went onto a chinese website, there are a lot of complains on the same problem. It seems so common on this product. Hope Nikon can recall this camera
Nov 23, 2007 | Fuji Finepix F50FD Digital Camera
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
Toshiba 32AF42 Poor picture quality
TRY ADJUSTING THE SCREEN CONTROL ADJUSTMENT AT THE BOTTOM OF THE FLYBACK TRANSFORMER.THIS SHOULD REMOVE THE RETRACE LINES AND ANJUST THE HASY LOOK TO THE PICTURE IF NOT YOU HAVE A BAD CAP IN THE SCREEN CIRCUIT .LOOK FOR A 10MFD/250V CAP IF FEEDS THE NECK BOARD ATTACHED TO THE PICTURE TUBE 200V DC.
Jun 22, 2007 | Toshiba 32AF42 32" TV
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
65 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
