Question about Frigidaire Affinity ATF7000E Front Load Washer
Keep the dryer from moving around on the washer
Dryer looks like its going to fall of the washer during spin
  • 350 Answers
It may be bolts loose in the back where Over Under washer/dryers are connected.
Good Luck!
Posted on Jan 19, 2009
  • Jack Iaria
    Jack Iaria Feb 01, 2009
    Thank You For Using FixYa adam gidusko!
    Does your dryer still look like it's going to fall off the washer?
The tub moves to freely and bangs on the washer sides
The tub shouldn't bang on the inside of the washer cabinet, as you already know. That is not a "normal" way for it to fail. Rather, I suspect something else. First try this: If you have your washer right next to your dryer, the washer itself is probably banging against the dryer during specific times during the wash - but most likely during the spin cycle. If you spread them apart a little bit - or stuff a towel or two between them, you may find that it stops banging. The washer may also be hitting something other the dry, too. Check all around the washer - try to keep and inch or two between it and anything else. If it still is banging - then something else is causing it.
Jun 10, 2011 | Maytag Washing Machines
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Washer is convulsing and moving around during
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | GE WSXH208A Front Load Washer
Very noisy and moving around Hotpoint washing machine
there are four shipping bolts in the back of the washer that need to be removed they are long bolts connected to plastic pieces. unscrew them and remove the plastic pieces
Oct 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
Apr 27, 2009 | GE WSM2780DWW Unitized Spacemaker Washer...
Jumps around
Mine did this, it never got fixed, repairman told me to replace it. I suggest you do the same. He told me the springs and bumpers had just worn out, and from the looks of my old washer, he was right lol
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator fall off and knocking noise during spin cycle
there should be a rubber washer with the bolt. if it is missing the bolt may back of during agitation. also the threads on the transimision may be stripped. Some Green lock tight found in most hard ware stores should help. the knocking noise is probably due the agitator coming loose.
Sep 16, 2007 | Maytag PAV2300 Top Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
