Question about Sharp LC-32P50E 32 in. LCD Television
Television wont turn on, just stays on standby
I was given this by a friend who had had it in storage for a while, when plugged in the television goes to standby but does not seem to respond to the remote turning it on (there is no on button on the casing of the television). The batteries in the remote are fine. I have a small knowledge of electronics so am able to change resisitors etc on boards
SOURCE: Sharp Aquos 32 inch television
TRY PIP BUTTON
Posted on Dec 23, 2007
zjut
  • 106 Answers
SOURCE: Sharp Aquos blacks out using PS2 & DVD player
Try to replace the main digital board.
Posted on Jan 13, 2008
  • 899 Answers
SOURCE: Remote's menu and input buttons, and television Input button not responding
well the problem sounds like it could be the IR sensor on the tv or somthing in that circut that is failing or the EPROM chip that controls : Vol up/down , Channel up/down , Power on/off ,Menu , Input selection , ect... is failing, thus this will trigger the protection circut to shut the tv down. this kind of a problem only gets worse and can dammage other components if not repaired soon so it will need testing to determine the exact cause
Posted on Oct 14, 2008
  • 541 Answers
SOURCE: I just purchased a used Sharp Aquos 32 LCD model #
Try encompassparts.com and see if they have the original remote. The channels you are getting are digital channels. You are going to have to get it back to analog channels.
Posted on Oct 13, 2009
BoiseLCD
  • 63 Answers
SOURCE: television isnt working correctly
Are you changing the Video Input selector to the proper HDMI port? AKA the SOURCE button.
Couldn't decipher if you said that you've used another console with HDMI video on the Sharp Aquos already.
Posted on Jun 08, 2010
Four flashing red lights then one green - no picture. This hapoens when I try to turn it on, The screen stays black and has white horizontal line.
Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Oct 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a 52in ilo flat screen television that just stopped turning on. It stays in standby mode. It use to come on and periotically would stay in standby mode. It is now stuck in standby mode.
Check and replace its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 17, 2014 | iLO 3200 32 in. LCD Television
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
My standby light is blinking and the screen wont come on. is there anyway to fix it?
This is from the Sony support site...
URL to page
"The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center."
Jan 24, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
50 inch samsung wont turn on standby continues to blink
Try unplugging it from the wall for 5 minutes and plug back in .. let me know what happens
Jan 03, 2009 | Samsung DLP HL-P5663W 56" TV
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Sharp LC-32P50E 32 in. LCD Television Logo
42 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
