Red tv switches its self of 2300 every night wonre switch back on ontell next day
  • 8,617 Answers
Sounds like the timer controls are set for a shut off and turn off at a given time. I will need the model number of the set to assist further. Please respond to this same post for assistance.
Posted on Jan 02, 2013
SOURCE: TV is tempremental switching on!
I had the same problem ,is it plugged into a single socket outlet or a power board? If a power board it can cause problems, try plugging straight into the socket on its own and see how it goes.
Posted on Mar 28, 2008
scott201201
  • 170 Answers
SOURCE: Red Screen
try tapping lightly on the tub that matches your color problem.
do you see it come and go? if so then you have bad tubes.
you can try to rejuvenate them but is not recomended.
Posted on Apr 10, 2008
SOURCE: sony wega 42inch
Power surge has damaged power supply, have serviced
Posted on May 10, 2008
  • 556 Answers
SOURCE: sony lcd projection tv in self diagnosis mode. 4 red flashes
This is a fan error take the back off the set and see if the fan is turning.
Posted on Sep 15, 2009
  • 979 Answers
SOURCE: MY SAMSUNG TV SWITCHES OFF BY IT SELF
Good day sir/maam, the swiching off thing can be caused by the setup of the sleep mode. check your remote and set the sleep mode to off.
It could also be a failure of the switching power supply board. This symptom needs to be checked by an authorized service service center, better call or visit your local dealer, for proper advice on your TV. Hope this helps.
Posted on Oct 13, 2009
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
May 29, 2014 | Televison & Video
I need the instruction manual. Also, what is the top red light for? Just what does it do
Hey, you got you self a Russian NV monocular. There should be two switches. One switch is to turn on/off the unit. The second switch is used to turn on the IR illuminate--which means infrared red light. To improve the night capabilities of the NV monocular. Ther are two LED's one green for on/off switch and one LED that is red for the IR illuminator.
NO-NO-NO's
When the NV monocular isn't been used, take the batteries out. The worst NO-NO's is looking through monocular during the daylight hours. The do have metal front lens cover with a small hole in the center for a few minutes of viewing during the day. Remember---Use Only During the Night---Do look at bright lights, don't let the kids play with it and make dam sure that Grandfather doesn't get his hand on it. He will be doing long range peeping at the neighbors or the lady that leaves here blinds open during the. Kid-No, Grandfathers-N0, Fathers-that up to them. If pop going some night look see. I'll make a bit his survival ratio has raised demise by 70%. stewbison
Feb 11, 2011 | Kalinka Cyclop 1-V (NZT-1M2) Wide Angle...
TV TURNS ON BY ITSELF IN MIDDLE OF THE NIGHT HELP
If you have eliminated the obvious things the tv must have a fault...
The obvious things - a night prowler with a remote, a cat walking across your remote, a ghost that likes to watch tv, somebody sleepwalking...
It is possible the infra red signal needed to switch on the tv is not coming from your remote. You can test this by removing the batteries or taking the remote to bed with you. If the tv still turns on then tape over the infra red receiver on the tv to eliminate the chance of some stray infra red beam from elsewhere being the culprit. If that stops the tv turning on you need heavier curtains or blinds or the tv moving perhaps, but if the tv still switches on it has a fault.
There is another thought. Digital TVs and digiboxes are often programmed to wake up periodically to check for software updates. Mine wakes up at 3am but it only checks for software updates and doesn't switch on the tv, but maybe this is what your tv is doing.
A further thought - a tv often has the functions of an alarm clock. They have a sleep function so they can switch themselves to standby after you have fallen asleep and then can wake you in the morning. Perhaps the alarm has been inadvertantly set for 2am?
These days it is rather anti-social to leave any appliance on standby. Rather than unplugging the set every night and worrying about the kids, why not arrange for the tv to be plugged in to a switched outlet so the kids can switch it on or alternatively use a cheap plug-in timeswitch to prevent the set switching on in the wee small hours...
Apr 16, 2017 | RCA F25442 25" TV
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Oct 23, 2009 | Mitsubishi WD-62531 Projection Television
WLAN troublshooting
first you wi-fi enabled on the hub.Secondly want to check that your wireless network adapter is switched on. Some laptops come with a small blue or red button on the side.
May 20, 2009 | Acer TravelMate 2300 Notebook
The tv wont turn on. i checked the fuses on it and the power connection. i turned it off one night and the next day it wouldnt come on.
It sounds like the tv is not passing its self test at turn on, If you have the owners manual you can use the pattern of the indicater LED's at turn-on to zero in on the problem. It could be one of the fans not working. If tv is not powering on at all, I would check the rear panel safety switch inside the rear cover. It wont let the tv power on if switch isn't fully depressed indicating the rear panel has been removed.
Good luck,
techjoel
Apr 03, 2009 | Samsung HCN4226W 42" Rear Projection...
Tv wont turn on
i have a nlc-3204bc funai hd ready, the stand by light keeps flashing red on and on, can not switch it on
Feb 17, 2008 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
