Question about Canon Office Equipment & Supplies
Mi PM810 tiene encendida luz naranja fija y la pantalla con muchas rayitas
SOURCE: parpadean los dos botones el de el bote y la de la tinta
alex, te tengo malas noticias yo tambien trabajo con estas impresoras llevo 4 dañadas de igual manera, la epson en estados unidos te la cambia antes del año de garantia, es de pensar que seben que tiene su defecto que parece ser no tiene remedio, si llegas a encontara el reseteador me lo pasas yo hare igual contigo.
Posted on Nov 13, 2009
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
pineworks
  • 4041 Answers
SOURCE: Problema con impresora MFC-3420C
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Posted on Mar 01, 2010
muntejaya
  • 10421 Answers
SOURCE: Mi nombre es Carlos Molina
Well, get it downloaded at : www.nodevice.com/driver/company/Lexmark/Printer.html
www.lexmark.com/
www.driverslab.com/drivers/Printer/Lexmark/9/63.html
Regards, Jaya_Gin
Posted on Feb 12, 2011
Printtech
  • 1087 Answers
SOURCE: cuando conecto el cable usb
Por favor, el cable USB quese conecta la impresora y la computadora, asegúrese de que está correctamenteconectado. Compruebe si el equipo detecta la impresora por medio de cheque enadministrador de dispositivos. Intente cambiar a otro puerto USB, si tienecable USB adicional intenta utilizar un cable diferente. Una vez que elordenador detectará la impresora, aparecerá una notificación en la esquinainferior derecha de la pantalla que un nuevo dispositivo ha sido detectado.Paraobtener asistencia adicional, póngase en contacto con asistencia técnica deLexmark.
Posted on Jul 19, 2011
Porq no enciende pantalla del radio mitsubishi lancer 2009
donde va el relay que mencionas amigo? me paso el mismo problema
Jun 07, 2012 | Cars & Trucks
Jeep liberty 2004 se enciende una luz en el lado derecho del tablero de color naranja q es
Exactamente cual es la luz que ve en su tablero...
Comentenos para poder darle mayires detalles.
Nov 24, 2011 | 2004 Jeep Liberty
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Buenas tardes, mi equipo es una EOS Rebel XSi, al querer sacar el flash no se acciona y me envia un mensaje en la pantalla solicitandome Err 05 "Se obstruyo la salida del flash, Desconecte y conecte el...
tal vez el boton del flash esta en off apagado o en automatico y esta en un lugar con mucha luz por eso no se acciona busque en el cuerpo de la camara el boton del flash y accionelo hasta que se prenda o se ponga el dibujo en la pantalla de el falsh
Sep 28, 2010 | Canon Cameras
Abri mi terminal Verifon vx510 para darle mantenimiento pero cuando la volvi a cerrar solo parpadea la pantalla, creo que se activo el tamper como lo desbloqueo o restauro, algun switch activa esto
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es dawer_2010@hotmail.com
Jun 09, 2010 | VeriFone VX510
La computadora se traba cuando conecto el cargador de la pila
Tal vez hay un problema con el cargador. Normalmente, usted puede cargar la batería con la computadora. Trate de comprar otro cargador. Pero antes de comprar, probar el cargador de nuevo en primer lugar.
Sep 14, 2009 | Toshiba Satellite R15-S822 Tablet PC
Ayuda para desbloquear
buenas tardes tengo un tv modelo HTV-2115 y tiene un candado rojo en la esquina inferior izquierda el canal no lo deja de mostrar y donde deberia tener la hora aparecen las rayitas no me deja usar el control sino para apagarlo y de los botones laterales solo lo puedo apagar como puedo desbloquearlo sino me da acceso al menu ni con el control ni con el menu lateral. darme respuesta al messnger viittoria1997@hotmail.com Gracias es de Venezuela
May 24, 2008 | Televison & Video
Pixma MP160 not faxing
ERROR E27
Hola gente no lo consigo ni por un lado ni por otro.
Alguien lo ha conseguido ???
Sigo las instrucciones al pie de la letra:
Describo las teclas que he usado:
parar -> tecla en roja que tiene un circulo y dentro un triangulo
on/off -> tecla que pone on/off arriba
1- Pulso y mantengo pulsá la tecla de parar
2- pulso y mantengo "on/off" y suelto parar
3- teniendo pulsada "on/off" pulso dos veces para y en la segunda suelto para y on/off
4- la impresora se enciende y pone un cero en el contador
5- pulso una vez la tecla parar se enciendo la luz de la izquierda que es naranja la que esta con el triangulo y un rayo dentro
6- pulso otra vez para y la luz se va a on/off
7- pulso para otra vez la luz pa la izquierda es decir triangulo y rayo
8- pulso otra vez para (ya van 4 veces) y la luz pasa a on/off
y ahora que....
por que yo pulso ahora on/off y la impresora hace ruido pero la apago la vuelvo a encender y las luces de falta de tinta, es decir la de la B y la C siguen encendida
no se que hacer he mirao por todos los foros del mundo estoy a punto de tirarla por la ventana y comprarme otra
saludos
Apr 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
old marine
old marine
