Question about Hitachi P50T501 50 in. Plasma HDTV
Hitachi Plasma picture problem
Hitachi P50T501 50" plasma
1 yr old worked perfectly until today
bottom half of scrteen alternating lines all the way across are black/blank.
Same on all MDMI inputs - it's the TV not input device.
Unplugged and replugged after 10 min - same problem
  • gregcable Jan 19, 2009
    Tried disconnect tried many restarts. Warrenty was one year - we're at 14 months.
    Overnight unplugged in a very cold room.
    This morning exact problem continues.
    Scholar:
  • 87 Answers
Unlike some of the other responses you have recived this one may actually be helpful to solving your problem.There are actually 4 diffrent modules in this unit that could be causing this problem.The control logic board is pretty much the brain of the unit. It tells the Y-sus board what to send to the X and Y drives.The x and y drives are the modules responsible for what you see on the panel(or the picture you see) I as a technician cannot tell you which of these modules is causing the problem without physically troubleshooting the signal path.But to answer your question you either have a bad control board= $125.00,a bad Y-sus board=$287.00,or a bad X-drive or a bad Y-drive=$175.00.If you order one of these boards you still may have the same problem.Your guess is as good as mine at this point,but a good service shop in your area could eliminate the guess work and have your unit up and running in no time.
Posted on Jan 19, 2009
  • 4,234 Answers
First of all, let me appologise for the responses thus far. There is no CRT nor any adjustments on the "back of the tube". Also, there is no effect on the set of any magnetic fields generated by speakers.
That being said, the problem you describe is likely to be a defective processing board. Rather than start there however, since the set is no longer under warranty, open up the back and remove and reinsert all cables and connectors. The digital signal levels are so small, that it takes only slightly poor connection to introduce noise in the signal. While a long shot, it is possible that a connection problem can cause this symptom.
In the meantime, I'll look up the part numbers for you.
Please update this with the results of the connections.
Thanks,
Dan
  • 744 Answers
Hi.. its better not to mount ur tv on wall and place it in any flat surface. the reason for some alternating lines is that some capacitor circuits would have got damaged. if you consult any electircian he would try to remove those lines by means of grabbing a magnet over that shaded area. so that ur problem might get solved.
    Genius:
  • 2,920 Answers
On a tv like that id send it to a shop and have it repaired and not do any guesswork if its still that new. people can tell you all kinds of things are wrong with it but you would be better off sending it to a professional and letting them fix it right the first time,,,
  • 684 Answers
Unplug the TV from the wall socket and keep that idel...... Check whether there are any magnetic items kept nxt to the TV...........If yes Remove them........ Replug in the TV after 4 Hours and then try to use it........ It Should Work........ Good Luck..........
  • 119 Answers
Hope your tv is under warranty. Contact the manufacturer. I would try disconnecting the TV and put it out on your porch for 20 minutes(assuming its cold outside).. Sometimes this helps if their is a circuit board problem.
  • 11,896 Answers
From your description I feel that you are talking about line tear , if you have access to line hold ,or horiz hold, or hor freq controls then a small adjustment may cure it.
If this doesn't cure it try unplugging it for at least 4 hours. This is called a Hard Reset.
Either one of these should cure it.
If neither one of these suggestions work that means the vertical deflection system, probably the amplifier, has failed
  • 3 more comments
  • Nate Stansfield
    Nate Stansfield Jan 19, 2009
    usually the adjustments for the tube are in teh back of teh televison. You must remove the back cover to access them
  • Nate Stansfield
    After studying my repair and owners manuals, I have came to the conclusion that one of the system boards needs to be replaced by a certified technician. This is not a problem that can be fixed with adjustments.
  • Nate Stansfield
    Nate Stansfield Jan 23, 2009
    After further investigating I've come to realize that your RESISTOR PACKS are shot
  • Nate Stansfield
    Nate Stansfield Jan 24, 2009
    First try to remove back panel off tv. then find adjusting screws for you picture. NOTE position before adjusting so you can go back to the same exact one if it didn't work. If none of these adjustments correct your line problem then it is due to hardware failure. Most likely your packs.
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    THERE IS A PROBLEM WITH YOUR CRT'S OR YOUR FLYBACK
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Having a problem with plasma tv hitachi
It will depend on the age of the set but the lines are either a bad board or a bad display unit .
Dec 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
55 inch hitachi plasma
Try re-seating your upper and lower buffer board connectors. These boards run the length of the set on top and bottom. Since your line is from the top going down I would check that one. The connector will be close to where the line is showing up on the screen.
Jun 18, 2009 | Hitachi 55PD8800 55 in. Plasma Television
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Hitachi 50" plasma no picture
how do i fix p50h401 blue light no picture and sound
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Thin red line on Hitachi plasma
If it goes all the way from top to bottom, you have a bad panel. much to expensive to repair
Aug 10, 2007 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Hitachi P50T501 50 in. Plasma HDTV Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
