Machine does not pump all water out and after while PU flashes most of the time its just at the end of spray rinse have checked the pump and it dosnt appear to be blocked but impellor may be a bit worn does the pump out cycle work on a timed period or a sensor ??
  • Washing Mach... Master
  • 17,130 Answers
Normally the spraying is done with a timed sequence as it depends on the program choice. So if this is a hard wash the timing will be longer.
The pumping pressure will depend on the pressure pump and water input. If low you need to check for clogging of the pump. Also residual water in the machine is due to poor drain, fault in drain pump, dirt accumulation in drain filter. remove and clean.
Posted on Jan 02, 2013
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 521 Answers
SOURCE: Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Posted on Aug 24, 2008
SOURCE: Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
Posted on Nov 24, 2008
kf4rwe
  • 25 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Posted on Dec 03, 2008
canbruce75
  • 1776 Answers
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Aug 27, 2009
Cycle has stopped 31 mins from end and has lit up check water. No blockage and this should be the drying cycle. Is this a repairable problem or not as it is old?
On many older machines, there was only one water pump. During the wash and rinse cycles, the pump would cause the water to spray the inside of the cabinet. At the end of the cycle a solenoid would open a valve and the pump would then cause the water to be sent to the drain. There are a couple of ways to check for this. Ordinarily, you would hear a knock or thump when the solenoid operates. Another way to tell is if you still have a lot of food particles during the rinse cycle - particles that should have been drained out at the end of the wash cycle.
Some solenoids were not particularly expensive and are fairly easy to replace. If you post your make and model number, I can get more information for you.
Apr 05, 2016 | Dishwashers
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
How do you ascertain if its drain pump or faulty controller board causing a fault 37 on a gw612?
Read the answer in the link below first, but in your case it can also be a faulty or blocked diverter valve. If you are good with a multimeter check the resistance of the pump windings. It should read around 33 ohms. It is not uncommon for the pumps to cook themselves and you can smell and see the burned out motor. I hope this is of some help
http://www.fixya.com/support/t25754844-error_code_37_fisher_paykel_8_5_kg_front
Jul 24, 2015 | Fisher and Paykel Washing Machines
Dish washer not washing dishes water coming in but the arms are not spinning am thinking the pump may be gone the model is omega dw501wa
Hello; this dishwasher has a pretty poor track record, but since you have it, I'd suggest the obvious solutions first. You only mention that the spray arms aren't spinning. If this is the ONLY problem, and the dishwasher empties properly, the problem has to lie in the spray arms, since the same pump that runs the sprays pumps the water out of the dishwasher.
If you have the manual for the machine, remove the sprays and check that they are clear of all debris (small pieces of bone, plastic, glass, food) that are usually removed when you rinse the dishes prior to putting them in the dishwasher. These small particles are blown into the spray holes when the sprays try to run, and block the holes. Often, they drop back into the spray arms when the pump is off, so they aren't visible on inspection. For this reason, smack the spray arm into the palm of your hand sharply, then shake the arm. If you hear rattling around inside the arm, it's debris. It's a little time consuming, but you need to get it out, and check for this problem regularly.
While the arms are off the fittings, close the dishwasher and start the cycle. Once it reaches the point where the sprays come on, if the pump IS working, and the debris screen on the food chopper is clear, you should hear the water gushing inside.
If you DON'T hear the water gushing, the next thing to check is the food chopper debris screen.
If all else fails, and the washer does NOT empty at the end of the cycles, you probably have a pump problem.
If that's the case, considering the history of these machines and the cost and labor involved in installing a new pump, you should consider getting a new, more reliable machine. Check Consumer Reports next time. (;<)....Good Luck!
Jun 16, 2012 | Dishwashers
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Our simpson washing machine is not spoinning and the letters PU flash on the electronic display panel.
PU is pump fault. Usually caused by a blockage. Machine will not spin until all water is drained
Thank You
Sep 09, 2010 | Washing Machines
Flashing lights on Hotpoint FDW20P Dishwasher
No solution! tried resetting to factory defaults but ended up that even the drain pump stopped working. after flooding the kitchen (nearly). I decided it was terminal and am loking for a new dishwasher urgently as I type. Cheers.
Feb 18, 2009 | Hotpoint 24 in. DWF32P Free-standing...
Kenmore Elite Washing Machine with Calypso Wash Motion Model # 110.22066102
have you removed bottom panel and cleaned pump..old style pump was held om with clips but the splined shaft in the pump would strip out and never pump properly only solution was replace pump/motor assembly..new style pump had 4 screws in bottom and could be removed and cleaned
Aug 21, 2008 | Washing Machines
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Dishwasher does not spray water
It sounds like your dishwasher is doing everything normal EXCEPT washing. The unit fills properly, the timer advances properly, the unit drains and goes through a rinse cycle, plus the water is heating. I would check your main wash pump for obstructions that may be clogging it, or if it is not running at all, you need to check the interconnecting wiring and/or something in the wash pump circuit that would prevent it from running. There should be a wiring diagram/tech sheet located behind the lower kick panel under the door. I hope this helps some. Good luck and let me know what you find.
Jul 07, 2007 | Ariston Technologies LI640S Dishwasher
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
