No samsung wont work for an LG however you can get the remote for your TV from www.tvrepairworld.com
SOURCE: LG plasma tv 42 and 50 inch
I have a 42inch LG plasma TV. It has a 4 inch wide stripe on the right side from the top to the bottom that is all different colors and goes from the topto the bottom.
SOURCE: lg plasma after storm doesnt want to turn on
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
SOURCE: I have an LG 37 inch LCD. The remote control
Most of the time it is the Main Board in the TV that the sensor plugs into. They have had many issues with this Board causing this problem. To be sure, you will need to call a professional.
Hope this helps,
Skyassoc
SOURCE: just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
SOURCE: LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
