Question about Seiko SNXJ92 Wrist Watch
The minute hand on my seiko 6T63 stops every hour
5 Suggested Answers
  • 188 Answers
SOURCE: How do I safely remove the crown of SEIKO ladies wristwatch
it might just lightly push on but not expert at this. clocks do. and some watches do. thats a fact.
Posted on Mar 26, 2009
SOURCE: hands problem
Download the instruction booklet from here
http://www.seiko.co.uk/support/instructionbooklets
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: seiko watch stop watch needs resetting
You can download an instruction manual for your watch here. It will detail how to reset the hands. :)
Tom
Posted on Jan 03, 2010
  • 4 Answers
SOURCE: Seiko SGF204 second hand hesitates or jumps a
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
Posted on Feb 28, 2011
Testimonial: "Many, many thanks a new battery fixed it."
Hello. I have a Seiko 7t62 ojpo chronograph. The small second hand will run for about 20 minutes then stops. As a result, the main minute and hour hands stop working. Everything else works. Any ideas?
You have a fairly premium watch and some versions are more premium than others. Your watch clearly needs attention and that should be entrusted to a Seiko dealer or to the manufacturer. Once the case has been opened the sealing must be retested to ensure it meets specification. If this isn't done as part of the repair or service or battery fitting there is little point in having a watch with such a high specification.
Jan 04, 2017 | Seiko Watches
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
Feb 28, 2011 | Seiko SGF204 Wrist Watch
My watch has had the battery changed and when you reset the stopwatch, the second hand and the small hour/minute hands no longer rests on 12. How do I reset these hands
I have the same problem with my Seiko Coutura Chronograph. Ever since battery was changed, the stopwatch resets to 32' 8" instead of 0'0". How to re-zero the hands?
May 08, 2010 | Watches
I have a Seiko Titanium Chronograph certified water resistant to 20 BAR. The movement # is 7T62-0BZ0. I recently had a jeweller put a new battery in the watch and it has not been working properly since. I...
DO AMASTER RESET TO YOUR WATCH!PULL FULL OUT THE STEM(CROWN)THEN TURN THE HANDS TO THE RIGHT TIME THEN RESET THE CHRONOGRAPH AND THE ALARM WITH THE TWO BUTTONS(SEE YOUR MANUAL.IF YOU HAVENT TRY TO DOWNLOAD IT FROM ANY SITE OF SEIKO SUPPORT).THEN PUT THE CROWN IN.IF THE PROBLEM REMAINS THE ONLY SOLUTION IS THE SIKO SERVICE!THEY ARE NOT EXPENSIVE AND MAKE GOOD WORK!DONT GIVE THE WATCES EVEN FOR THE BATTERY TO THE MONKEYMAGICIANSGURU JEWELERS THEY ARE WATCH RUINERS!
Dec 06, 2009 | Seiko Alarm Chronograph Titanium CASE AND...
Hands problem
May 05, 2009 | Seiko SNXJ92 Wrist Watch
How to change the hour
Anniversary clock hands can be adjusted directly moving the minute hand clockwise. Do not touch hour hand as this may cause hand disalignment. Carefully move minutes hand with your finger all the way around till you reach desired time.
Do not forget to rate, please.
Mar 09, 2009 | Seiko Clocks Melodies In Motion QXM135BRH...
Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
Mar 01, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
Seiko SNXJ92 Wrist Watch Logo
143 people viewed this question
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
