Question about Xerox DocuColor 12 Color Copier
Docucolor 12 printing nothing from glass
Hi, I just tried printing from the glass and now it is printing nothing. It was printing before when you asked me so this might be something you know. However, I don't get an error code. When I connect the fiery to another Docucolor 12, it works so I know it is the copier. Could this be the fuses? Thanks, Keith
  • howsimple Jan 19, 2009
    Thank you for your help. I found a loose connection on the Vsel pwb. By the way, what does ROS and pwb
    stand for? I see it all the time, but never bother to know what it
    stand for.
  • 62 Answers
The only fuses it could be are the 24v fuses going to the ROS. In general it would "normally" be the ROS and Halftone pwb or the Vsel pwb. Both of these might not be sitting right/loose ribbon cables etc, depending if you have been working in that area.
The other option is a defective cleaner clutch for the IBT. This "normally" leaves with just the black left on the print however. You will have to watch the machine and see if there is actually an image being produced on the drum. If not, the ROS (ROS and halftone pwb must always be replaced together)
Posted on Jan 19, 2009
  • oooimstuck Jan 19, 2009
    ROS = RASTOR OUTPUT IMAGE
    PWB = is just describes a circuit board, I've never really bothered to find out myself, probably something like printed wire board or something daft. every board is a PWB though, as you've probably found
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 Not Printing with another Fiery
could be a few things, the ips pwb in the machine might be faulty, which can cause these types of issues, a driver issue woth the video boards on the fiery, or other pwbs on the machine itself. You would have to run the machine for a while on another fiery to make sure no other faults occur before condemning the machine or the fiery
Jan 17, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
the only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch 1-7QU5B.ps from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Docucolor 12 Problem
You can find the POWER SUPPLY box at the bottom right corner on the right side of DC12.
Dec 28, 2008 | Xerox DocuColor 12 Color Copier
CMYK spots on print
- Please check properly if they have Leek?
- Try to clean the Glass inside and out-side the machine
Sep 20, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
130 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
