Question about Dishwashers
I cannot remove the bottom filter trap and not sure whether it's necessary
  • 17,129 Answers
Please check on this link for tips: filter replacement
Posted on Jan 02, 2013
I have just rented an apartment with a Haier Front Load Clothes Washer & Dryer Combo XQG65-11SU. It says we need to clean the lint trap after every use. We can't access the lint trap. How do we...
Lint traps are usually inside the front door housing.check for spring loaded latch.it is never necessary to actually dismantle any major part on dryers otherwise it would not be user friendly.go online if you don't have the manual and check on the basic maintenance of the dryer.if it is a condenser dryer you might want to look at the bottom filter which is usually behind the kick plate...again easily accessed.
Feb 01, 2015 | Haier Washing Machines
How do I clean the trap filter inside my Electrolux Front loader
Good Morning Deanna - Sounds like you are speaking about the Coin Trap. Below are some basic troubleshooting steps you may wish to follow to clean the trap:
· Unplug the unit.
· Remove the bottom front access panel. There are two screws one on right and one on the left towards the bottom of the front panel.
· Now that the panel is removed look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
· Clean the drum out with as much water as possible that you can remove and have towels ready. The next step you will have the remaining water come out of the bottom of the drum and onto the floor.
· At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
· Reach inside the coin trap and clean what is inside of it out.
· Put the unit back together following the same steps backwards.
Hope this information proves to be helpful!
Jun 20, 2013 | Electrolux EW1000i Front Load Washer
Wheres the filter on a hotpoint first edition 1000 wm52
Trying to remember a specific model is a nightmare, but I can tell you, its in one of Two places.
Either it is behind the bottom panel at the front (Which clips off, and if it's there, it will be very obvious) or the bad news is, if it's not behind that panel, it's actually only accessible from the rear of the machine by removing an inspection panel at the bottom of the rear of the body. Some instructions that cover both possibilities are attached for you:
If hidden behind a clip on panel on the bottom, many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
If the filter is not located there, then you will need to access the debris trap from the back of the machine. Pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Give the boot a tug and reassure yourself that it is secure. Replace the panel on the back of the machine and test. All should now be well.
Jul 21, 2011 | Hotpoint First Edition WMA12 Front Load...
I washed a rug and the backing came off. I beleive the filter is clogged, as it will no drain. How can I get to the filter
Without the model, I can't be sure, but here are some generic instructions that will probably help:
Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
OR
You will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 19, 2011 | KitchenAid Washing Machines
After a wash cycle, the spin cycle will not activate. The light just flashes
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is either a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
OR
Jul 19, 2011 | Hotpoint WMA58 Front Load Washer
Water inside after ending
This is probably simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
OR
Jul 10, 2011 | KitchenAid KHWS01PWH Global Horizontal...
Hotpoint aquarius wmf940 wont spin or drain water out f05 fault how do i remedy this
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom ( behind the clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked. Ofter that, unscrew the round cap, remove the filter and clean.
If the filter is not there, you will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 10, 2011 | Hotpoint Washing Machines
How do I clear the drain trap in my Frigidaire LTF2140ES3
The filter is located in the coin trap hose that connects from the tub to the pump assembly. Remove the screws attaching the front bottom panel then pull the panel down and off the cabinet. Loosen the clamps that secure the coin trap hose to the tub and the pump assembly then clean the filter. Reassemble in reverse order of the disassembly steps.
Make sure you disconnect power before accessing the filter. Extract as much water from the tub to prevent flooding your floor. Also lay a piece of towel under the hose when removing it to catch residual water.
Oct 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Owen Barnes
