Question about Dishwashers
Water on the floor - Dishwashers
  • 17,130 Answers
Possible that there is leak on the gasket or the drain hose/pump. It is important to take a visual check of the bottom area to confirm the case. If the water seems to seep from the from the front door then the gasket must be checked , please click this link:
Door gasket
Posted on Jan 02, 2013
Remove mold on hardwood floor
Spray the oak floor with a 50% solution of white vinegar solution mixed with water and let stand for an hour, then clean with hot soapy water. Alternatively clean the floor with a steam mop, as either method will kill the mould on your floor.
May 24, 2014 | Shaw Solid Hardwood Floor 2 1/4" x 3/4"...
How do i stop my water pipes from rattling
Secure water pipes to floor joists, install a water hammer arrester. Try securing pipes first, they should be secured at every other floor joist. If you can't get to floor joists try a water hammer arrester.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
May 18, 2014 | Plumbing
Major water leak when it rains, water runs down driver side floor
Keep looking by covering area at hood etc and running water on the vehicle to locate where it is coming in---Windshield?
This is the best way if you cannot trace the stains from water to source.
Dec 10, 2012 | 1999 Ford Explorer
A/c leaking water passenger floor
Usually a sign of a plugged drain tube.
The HVAC box has a tube that drains the water onto the ground.
The tube should be at the bottom of the firewall near the passenger floor.
Jul 24, 2012 | 2002 Nissan Sentra
Have a 2008 Saturn aura. Water leaking on back passenger floor board. Was told that it could be clogged which was causing water leak. Took it to the shop, they said its not clogged. They said its the...
problem solved water in floor in drive floor an behind driver floor rear seat floor water in door drain holes was stopped up in door rain filled door up and over flow thru the panel into the floor of the car check by shake the door and see if u hear water that the problem drain holes is stopped up in the door poor design it also most under the weather stripping on the bottom of the door
Jul 19, 2012 | Cars & Trucks
2006 mustang water leaking rear floor
Hi , Its leaking water on the passenger rear floor? It could be the heater core leaking and running down the floor board to the rear of the vehical. Do you smell antifreez or see moisture build up on the windshield ? does the car seem more "humid" inside?
Jan 23, 2010 | 2000 Ford Mustang
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Sep 07, 2009 | Refrigerators
Is there a connection between a warm floor and a water heater?
Is the floor warm just in certain spots or all over. If just in a certain spot you may have a hot water line leaking in floor.
Feb 06, 2009 | Ruud Central System Air Conditioner
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
