Question about Memorex Mini TravelDrive 4GB Pink Pais 98594 Media
My memorex 4GB memory stick has completely stoped working and is un-formatable im not sure why but at the moment its completely useless. what can i do?
I dont know whats going on but it wont work...
  • Memorex Master
  • 27,725 Answers
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply Hope this helps.
Posted on Jan 11, 2013
My 4gb memory stick pro duo didnt work on sony vaio vpcw21eag card reader magicgate hg duo.. pls help me... my operation system win 7 ultimate.. help me...
if your 4gb memory stick are not working,i suggest format your 4gb memory stick and use. step for format it , Right click on my computer and click on manage after open manage window click on Disk management tab after few second your 4gb memory stick are display it, right click on 4gb memory stick and format, select quick format , ok after few second complete format message are display , click ok and use your 4gb memory stick.
Jun 22, 2011 | Computers & Internet
When i go on my psp i wuz puttin a game on it then i turned off my psp then it goes nd says memorycard can not be read then i keep trying to format then it say after it done that it says no memory cad...
  • 1 Insert the problematic 4GB Memory Stick Pro Duo into your PSP and turn the system on.
  • 2 Select "Settings" from the cross media bar and scroll down to "System Settings." Press "X" to access the sub menu and select "Format Memory Stick."
  • 3 Press "X" to confirm the formatting of the stick. Your PSP will delete any content on the stick and reformat to match how the PSP stores data and organizes files.
Jun 04, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
When i try to format my memory stick, i get an error message that says "windows cannot complete format"
It sounds that it just needs a different form of formatting try selecting a different option NSTC or FAT
Jan 24, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
THIS MEMORY STICK GIVES ME ERROR MESSAGE WHEN I INSERT IN IN MY CAR ALL OTHER STICKS WORK BUT NOT MY TANSCEND 4GB HI SPEED STICK
my 4GB memory card insert to my mobile then say format your memory card but not working and no format card.
Oct 29, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pen drive capacity is 4GB but its showing 200MB in my PC and in other pc and it is not storing more than 200 mb size file ?how to solve this and how can i re find my free space of 4 GB and i can use it?
Copy all the files from the memory-stick onto your disk-drive.
Then, open My Computer.
Right-mouse click on the icon for the memory-stick.
Choose Format.
Choose Quick-Format.
When it completes, it should show as 4GB.
Copy the files back onto the memory-stick.
Oct 11, 2010 | Kingston Electronics - Others
Can't write onto my card through adapter, only works through the phone. "write protected" keeps coming up. No lock on adapter.
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
Jul 14, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
How to format a sony 4gb memory stick pro duo
Why do you need to format. If using on Sony products its ready to go no need to format. If needing formatting your PC will tell you so and will give you the option to do so by selecting yes to format and will do it for you.... Do not format unless prompet to do so
Oct 01, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Formatting
Mr Jacques,
Welcome to fixya free solutions. First I'd advise you not to re-insert your mem stick again in SE before formatting. Take a nokia cell from any of your friend. fit it in Nokia set don't try to browse the mem card simply click options and format it. It will easilly format the stick and now you can use it in your SE set also. If you face any problem kindly do comment back.
Aug 05, 2009 | SanDisk 4GB Memory Stick Micro M2 Memory...
When i turn on my camera ,memory stick formatting error comes up
If it is Sony DSC-T200 camera then use maximum 2GB memory stick as it can not handle 4GB memory.
Feb 25, 2009 | Sony Cybershot DSC-T200 Digital Camera
Memory stick
Connect your psp on your computer and after go in the file
MY COMPUTER and right click where your psp icon aprears amd there will be many options. To format your memory stick just click on FORMAT. If it doesn`t work you can just go in your psp menu and go to system settings and theere if an option called format memory stick. It will automatically fix your memory stick and after formatting it your memory stick will be completely empty and it should work.
Mar 08, 2008 | Sony PlayStation Portable (PSP) Console
Memorex Mini TravelDrive 4GB Pink Pais 98594 Media Logo
46 people viewed this question
Top Memorex Electronics - Others Experts
Stu Morris K
Are you a Memorex Electronics - Other Expert? Answer questions, earn points and help others
