Question about Ovens
My oven wont turn on the powers on but the fan won't turn on but all the lights and buttons work and I tried to access the micro switch but can't find it help please as I gotta cook a roast soon
  • Ovens Master
  • 8,457 Answers
Your oven fan it is dead.That why your oven is not functioning.By replacing the oven fan,the oven should power up and work and function again.
Posted on Jan 02, 2013
  • 883 Answers
SOURCE: My oven keeps turning itself off
the oven may be trying to protect itself because of a faulty device that says "I'm too hot". As electric clothes dryers have a thermal high temp limit switch to protect them, look for this device (may be 1 inch round with 2 wires connected) and replace it
Posted on May 24, 2007
  • 87 Answers
SOURCE: convection fan not working
Check for a bad fan motor or a jammed blade.
Posted on Jun 14, 2007
freetek
  • 5568 Answers
SOURCE: electrolux oven wont heat up after power cut
It may be necessary to actually pull the AC plug out and let it stew for a while.
Many electronic controls lock up with a loss, then return, of power.
Posted on Aug 03, 2008
wbwill
  • 68 Answers
SOURCE: westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Posted on Nov 11, 2008
SOURCE: Beko DCC4521
On Tuesday this week I had the same problem, purchased a new element, followed the instructions from Apprentice & my cooker is now working again to the delight of my wife & for saving me about £300. Thanks
PeterB
Posted on Feb 07, 2009
Door locked wont self clean
Turn off breaker for minute or so if no contact repair man mcro switch bad or out of position. Did he try to pull door right after candle. The motor takes time to clear the hook from the latch. If so he probly bent some thing in the mech that latches the door or on the switch plate that holds the micro switch
Apr 25, 2017 | DCS (WOTD-227) Double Oven
Oven light wont turn off
make sure the door is shut tight and making the switch
Jan 04, 2014 | Maytag 30" Built-In Single Electric Wall...
No power, door locked
there are 2 thermal switches within the component area in front of the fan of the oven, they open and close like a switch at certain temps,if one of these go bad (stays open after oven clean cycle)and oven cools then it wont let power back to the unlock motor,you can access these switches and bypass them to test them,if lock works then merely replace that particular switch
Feb 04, 2013 | GE Ovens
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
The oven wont turn on,fan works but heat wont come on
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer. Can give further advice if you provide a model number. Good luck!!
Mar 10, 2010 | Fisher and Paykel Ovens
Oven not heating
You need to replace the fan oven element.
access to it is by removing the rear panel in the oven, there you will see the element.
Plz rate my solution.
Thanks.
Dec 18, 2008 | Whirlpool AKZ159IX Oven
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
Smeg single fan oven
You are right, it could be a thermostat or a heater problem. You should check that the heater element receive power. In case it receive power,the heater element should be replaced. In case it doesn't receive power, the problem is with the thermostat. In any case, check as well that all wires connected to the thermostat and the heater are in place. Good luck.
May 02, 2006 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
95 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
