Question about Nokia 6236i Cellular Phone
Phone to PC bluetooth connection fails
I just got a Nokia 6085 and a bluetooth dongle for my PC. I installed the dongle, paired my phone with the PC and it worked fine, I was able to transfer some ring tones from the pc to the phone and I was very happy with the setup. Later the same day when I connected to the pc it would only last a minute and then I'd get a disconnect message. Now when I try to connect it immediately says connection failed.
I have rebooted the pc, turned the phone off & back on but nothing seems to work. I am running Windows XP Pro w/SP3, the dongle is a Targus ultr mini.
Im pretty upset that I just dropped money on a dongle and only got a couple of hours worth of bluetooth use out of it.
Any suggestions? I am totally new to bluetooth so please make any answers as simple as possible :)
After pairing if you answer cell phone calls on cell, the bluetooth will drop....you must delete pairing and then add it back and remember to answer only on house phone while they are paired.....
Posted on Mar 25, 2009
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
I m using c3 nokia i m not purchasing the usb so plz help me out to transfer the data from cell to pc and vice versa by using bluetooth,
To connect your phone using bluettoth, you need the following things.
1) Nokia PC Suite
2)Bluetooth dongle with the driver installed.
Things to be done on pc side :
1. give your host bluetooth name
2. find BTCOM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
Things to do on phone side :
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
For pairing :
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Nov 28, 2010 | Computers & Internet
I am pairing my bh 214 with my hp dv3 window7 it paired but giving response that driver is not installed
Tool; CSR bluetooth dongle 2.0, got from store for only $2.50.
Install Toshiba Bluetooth stack v7.00.10(T) driver Win7x64 (search in google to download the installer). from OFF state of your BH-214, press power button until LED flashes quickly,do not release the button yet, stay press until LED flashes red & blue alternately slowly.On ur PC,->Add new device, then your PC would detect BH-214 as headset. Work fine with my BH-214 to connect with PC through BTooth dongle (A2DP 1.2 (btooth audio profile) & AVRCP (player navigation control profile)) & at the same time with my phone (HFP, HandsFree profile).
Nov 24, 2010 | Nokia BH-214 Bluetooth Stereo Headset
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
How can i connect my motorola fone via bluetooth on my pc..thank you
Dear Friend
For Connecting phone via Bluetooth
  • Need Bluetooth Dongle
  • Install Bluetoth Dongle Software
  • Plug in it
  • Restart it(PC)
  • Run The Programme
  • Pair the Phone with PC
  • Share the Files you need between PC and Phone
You are Done....You can Feel Free Contact Me........
Is this Helped You.......RAte mE
Thanks For Using FixYa
Apr 01, 2010 | Motorola Mobility RAZR V3
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
on phone side
restart computer
pairing
1. add device
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
How do I move a ringtone I downloaded to my PC to my phone
bluetooth, memory card, or a PC cable. I find that bluetooth is the easiest way to put tones on my phone.
Mar 29, 2009 | Nokia 6085 Cellular Phone
Help!!!!
check on first place of ur phone already sets to visible for everybody then activate the both bluetooth
and see if pc can detect it
tell me more info so i can help u
plz rate this post as good as u can
Oct 09, 2008 | Nokia 6085 Cellular Phone
Nokia 6233 GPRS connctivity through USB blue tooth dongle and Nokia PC suite
There is some problem in your Bluetooth device driver. Try to uninstall it and restart your Pc then reinstall it.
Oct 05, 2008 | Nokia 6233 Cellular Phone
Nokia 6236i Cellular Phone Logo
122 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
