Question about Harman Kardon Go + Play Portable Speaker System for Apple iPod - Matte Black
Can my aux input be repaired for my dock Harman Kardon Go + Play Portable Speaker
Just let me if its possible ?? if yes then how ?? and pls tell abt the original parts ?? by the HK
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
Davidguitar
SOURCE: Harman Kardon Go + Play Portable Speaker Keeps Shutting Off
I just had this exact problem. I'm using an ipod mini. I solved it by docking the ipod firmly at the angle
the dock is at and have the ipod at an angle, not flat. I put the plastic and rubber adapter for the mini as instructed and also placed the rubber adapter for the nano upside down to keep
the ipod propped at an angle. (Also can use something similar to keep ipod propped up at an angle)
Took a while when I first used to figure out how the dock worked. The dock is a little weird how it is hinged to go from an angle to flat. Nothing in the instructions about this. By putting the ipod flat it would still have a connection to charge and play but the power shuts off every 10 minutes. I spent a whole night having it shut off every 10 minutes. This drives me crazy when systems have features like that which always seems to cause more problems (just my humble opinion)
By having the ipod at an angle I'm currently just now having it run an hour and 20 minutes and counting with no shut offs,(fingers crossed) but so far so good.
Saw on the internet that if the ipod is not connected firmly the system has an auto shut down. I think the ipod's weight propped at an angle keeps the connection firm. Also some said they want to see the ipod display, there you go!!!! This seems to be working so far for me, may be worth a try...I was about to return mine but I love the sound so I'm keeping mine now!!!! Works fine. Happy camper again.
Please reply if this works for anyone it worked for me.
Posted on Apr 27, 2009
  • 6771 Answers
SOURCE: harman kardon go and play don't have video out port
If I understand you correctly the Harman Kardon does not supply the output video and usb ports. Since this is a go and play they pobably felt it was not needed. to impliment these changes would require a complete design change.
Posted on Mar 28, 2012
I have a harman kardon go+play and the sounds not really good..i think the subwoofer problem,pls tell me what should i do? ty
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 28, 2016 | Harman Kardon Go + Play Portable Speaker...
The speaker is vibrating......help
Tighten the screws hold down the offending speaker. If all the screws are tight, and the offending sound continues, the speaker is defective and may have been damaged by over driving.
Jan 02, 2016 | Harmon Kardon Harman Kardon Go Play...
Is it possible to install aux 3,5 mm plugg?
Probably not, but you can buy a 3.5 mm.-to-RCA adapter cable to hook up a device with RCA (L/R) AUDIO OUT jacks (and no 3.5 mm. headphone jacks) to your Harman Kardon speakers which, I assume, have only 3.5 mm. LINE/AUX IN jacks (1 or 2).
Jul 15, 2014 | Harman Kardon Harmon Kardon SoundStick II...
When i connect my i phone 4 to my h k dock i get a message saying this accsesory is not supported in charging
It sounds like you have the version which was built before the iPhone updated and changed its dock slightly. It's still the same wide dock but like a lot of stations the updates to iPhone's hardware left compatiability issues. Most importantly, it will still sound perfect.
Nov 10, 2012 | Harman Kardon Go + Play Portable Speaker...
Harman kardon go and play don't have video out port
Mar 28, 2012 | Harman Kardon Go + Play Portable Speaker...
I have a denon ipod dock and a harman/kardon receiver. Can I connect the dock to the receiver?
To plug the dock into the receiver to supply power and interface with the iPod you would have to have one with a built in iPod. Most receivers will not do that, the most common way to connect an iPod to a receiver is using a 3.5mm to RCA cable. You don't even need the dock to do this, you can plug the iPod directly in. You can find this cable at most electronics shops if you don't want to buy online, like Best Buy or Radioshack.
Make sure you connect the white and the red end of the RCA cable to the correct sockets on your receiver, and the small 3.5mm jack into the iPod or the iPod dock, you have to turn the iPod volume up and select the corresponding input on your receiver. If you plugged the 2 RCA jacks (white & red) into the socket labeled "AUX" or "Video 1" you have to select "AUX" or "Video 1" in order to hear the sound.
Jun 18, 2010 | Harman Kardon Audio Players & Recorders
Dec 22, 2008 | Harman Kardon Go + Play Portable Speaker...
Jun 30, 2008 | Harman Kardon Go + Play Portable Speaker...
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon Go + Play Portable Speaker System for Apple iPod - Matte Black Logo
48 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
