Question about Dishwashers
Is it easy to get to the circuit board and how on the Westinghouse Virtuoso dishwashers?
  • 17,130 Answers
Please mention the nature of the fault seen on the machine. It is possible that a failure of the main circuit board means that in most case the board had to be replaced as there is very little that be done for component replacement except if the damage is clearly visible.
Posted on Jan 02, 2013
  • Daniel Sonn Jan 02, 2013
    Thanks, I'm just going off of similar posts on here. It's working fine but not heating the water
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Wiring diagrame for westinghouse virtuoso
Hi.
Service manual and wiring diagram for this model are not available. If you tell me what the problem is, probably I can help.
Here the parts diagrams for your model:
http://spares.bigwarehouse.com.au/file.php?document_id=17451
http://spares.bigwarehouse.com.au/file.php?document_id=17452
http://spares.bigwarehouse.com.au/file.php?document_id=17453
http://spares.bigwarehouse.com.au/file.php?document_id=17454
Here part list.
Posted on Sep 03, 2010
SOURCE: Westinghouse dishwasher virtuoso SB 925
I also had this problem of the water not heating up but the washer still did its thing. what i found was the problem, is the soldered joints on the circut board were cracked (dry joints) around the relay area, i just resoldered them and hay presto its all good
Posted on Sep 05, 2009
heatman101
  • 43501 Answers
SOURCE: My westinghouse virtuoso sensor wash
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in minutes...now the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Posted on Sep 24, 2010
SOURCE: How do I actually get to the circuit board on dishwasher
Hi All,
Great web-sitevery useful. To add, my SB907 has same problem - not heating. Found no open/short circuit in heater - found this forum - followed through with removal of circuit board and ... BINGO ! Dirty big black burn mark under relay ! Am now wondering if I can "just replace relay"... any thoughts? Thanks Rick
Posted on May 21, 2011
Westinghouse dishwasher SB908 short-circuiting power board
Your symptom is a little confusing, it's best to post a complete model number as written on the ID tag of the unit. This will help to provide better information. PLeazer Appliance...
Jan 14, 2015 | Westinghouse Dishwashers
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge- my top panel has gone blank - and everything in my fridge is now freezing - is there an easy solution to fix this ??
Sounds like the thermostat has failed to on and the machine just keeps freezing. Before replacing the panel try turning the power off to the fridge at the wall for 2 minuites and then return the power.
Apr 05, 2014 | Refrigerators
Electrical burning smell coming from control panel on westinghouse dishwasher
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
Feb 09, 2014 | Westinghouse Dishwashers
My westinghouse virtuoso sensor wash dishwasher isnt cleaning things as good as it should. I dont have a manual as I have just brought this house with dishwasher. Please help?
heatman101
Asker
Sep 24, 2010 | Dishwashers
Hi My westinghouse virtuoso does not heat the water any more and i wan to know were is the heating element located please
if you want to see all the parts you can go to searsdirectparts.com and put in your model # and you can view every part and location of your machine.let me know if this helps.
Mar 06, 2010 | Dishwashers
Undo the top two screws on each side of the back of the door and all the ones across the top edge. Then the panel can be manouvered away from the door. The catch mechanism tends to hold the panel back and there is only just enough free length on the wiring to pull the panel away a couple of inches, but it's enough to access the on/off switch and control module.
Feb 10, 2010 | Westinghouse Dishwashers
Motor starts but no water entering dishwasher
TRy priming by putting a jug of water in bottom of inside of dishwasher
Mar 04, 2009 | Westinghouse Dishwashers
Westinghouse dishwasher virtuoso SB 925 not heating the water and not drying the dishes , still workig thou. Would it be expensive to repair?
Aug 20, 2008 | Dishwashers
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Dishwashers Logo
129 people viewed this question
Top Dishwashers Experts
