Design jet 5000 - Office Equipment & Supplies
  • 32,281 Answers
If you are looking for the printer driver for this printer then -
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Posted on Jan 02, 2013
High altitude operation of a ryi2200 generator (5000 ft)
You require a high altitude carb (or carb jet) to operate correctly at this altitude. The jets are smaller to compensate for the thin air.
You need to get in touch with Ryobi to see if they sell them.
Do not adjust anything else on the generator!!!!
Dec 22, 2016 | Electrical Supplies
What should the jetting be for a 1994 yamaha yz 250 at 5000' elevation
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZ250 Jetting Yamaha 2 Stroke
jetting yz250 for 5000 Yamaha 2 Stroke
Yamaha YZ250 Owner Service Manual
OEM parts for Yamaha
Yamaha yz250 2015 Owner Manual
Apr 19, 2014 | 2008 Yamaha yZ250
Pilot jet bike will only idle down to about 5000 rpm no matter where I set the p jets,why?
Either your throttle cable is stuck, or the idle screw is turned up too far.
Nov 24, 2013 | kawasaki ZX-6R Ninja Motorcycles
Spluttering after 5000 revs wont pik up fitted with k and n and sport cans also once warm revs are high
If this has happened since fitting the K&N is most likely a jetting problem, try using the choke at 5000rpm if that helps go up a size in the main jets, if it gets worse go down a size. I cant remember if the 88 still had CV carbs, but air turbulance can cause the CV carbs to open erraticly as they are designed to **** from the air box which supplies air evenly to all carbs
Apr 27, 2010 | 1988 Yamaha FZ 600
Main jet and needle setting for 2003 honda cr250 at 5000 ft elev.
this should get you close, will still have to fine tune due to exacting conditions.....humidity, temperature, pipe, silencer and reeds....however try this:
Main 360
Pilot 20
Needle H1-70
Needle Top Clip
Air Screw 2 Out
Oct 08, 2009 | 2003 Honda CR 250 R
T140E 1978 starts runs at idle, quits on take off. Replaced floats and electronic ign. checked tank cap, fuel flow all ok. Replace main jets with #200. It seems to starve for fuel at take off. Been...
if your model has a amel mark 2 the stand main jet is #200 needle jet #106 pilot jet #20 starter jet #35 the main jet doesn't come into it at take off unless you are pulling 5000 revs or more. i would try raising the needles and checking the pilot jet also try taking of with choke on this will let you know if it is starving for fuel. try the choke one first before pulling the carbs down.
Aug 07, 2009 | Triumph Bonneville Motorcycles
I need a printer driver for hp designjet 5000ps os vista. If its not available is there another driver that can be substatuted?
If you google " hp printer drivers" it will take you to there home site and you can put your model # of your printer and it will give you 4 diffrent design jet 5000 printer drivers.all you will need to do is pick the model that you have and it will dowload it for you.i already checked for you to make sure..
May 16, 2009 | HP DesignJet 5000 InkJet Printer
14 people viewed this question
k24674
jasbo
jasbo
