Question about Car Audio & Video
The kenwood KDC-MP333 in my truck is connected to
The kenwood KDC-MP333 in my truck is connected to a set of kenwood speakers. But when I turn it on they won't work the stereo still shows the display but when I turn the stereo on it makes a sort of pop sound it won't play anything just makes the pop sound.
    Genius:
  • 1,669 Answers
Disconnect the speakers and try it with another speaker or speakers not in the truck. If it works, the speakers or the wires to them are messed up. If it doesn't you probably damaged the output capacitor in the radio by turning it on without speakers attached. Realize that the speakers are part of the radio circuit and act as resistance. Without them, there is no resistance and it puts a strain on the radio.
Posted on Jan 02, 2013
  • 4 Answers
SOURCE: Kenwood KDC-2011S display blinks
Download the MANUAL here.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=037b5697f7192f25431654464fa26ba6&q=Kenwood+KDC-2011S
Enjoy!
;) Mak
Posted on Aug 06, 2008
blackberries
  • 80 Answers
SOURCE: Kenwood KDC-MP438U and Nissan Pathfinder Steering wheel controls
you need an aftermarket PAC!
it will work just fine!
Posted on Feb 26, 2009
foskorider
  • 79 Answers
SOURCE: Kenwood KDC-MP438U reciever installed. No sound in any mode.
if its a newer truck it will most likely have a factory amp u either have to utilize or bypass
Posted on May 18, 2009
  • 87 Answers
SOURCE: i have a kenwood kdc-419 car stereo
Use a pencil eraser and try to clean the contacts on the back of the faceplate, if that fails it may have a cold solder joint on the inside of the face plate. May need replacement.
Posted on Jun 02, 2009
  • 35 Answers
SOURCE: I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Posted on Jul 28, 2010
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
I have protect displaying on my stereo
This is most likely due to speaker, speaker wiring, or faulty headunit problems. To troubleshoot this you need to slide the deck out and disconnect only the speaker connections. Turn on the stereo and if it still says "protect" then it's most likely a faulty deck. Otherwise, repeat the procedure of plugging in one set of speakers at a time until the "protect" comes back on. This is now your faulty speaker line. This could be the wiring or the speaker causing the problem so you could try swapping a speaker that you know works. If the problem persists you'll have to run new wire in place of the faulty line.
May 04, 2011 | Kenwood KDC-3031A CD Player
I have a kenwood kdc mp333 cd player, it reads cds and the radio is fine but therers no sound... like i turn it up and stuff but no sound.. is there a mute button on my cd player or would it be my...
Could be one or the other, look at every button on the face and ensure there is no mute button, although usually when you adjust the volume it will unmute. I would also look in back of the deck and make sure your wiring harness did not get disconnected, if it is connected you can try testing a speaker or two right from the harness and see if you get audio.
Mar 13, 2011 | Car Audio & Video
Hi , i have bought a car with kenwood kdc-mp333 audio player. i get an error protect all the time i turn it on. could u tell me how to solve this problem
More then likely it has an anti-theft system built into the radio. They only thing you can do is try to contact the previous owner if that isnt possible look for a really small reset button.
Feb 09, 2011 | Car Audio & Video
Kdc mp333 car stereo in protect mode.2nd hand car, how to remove? please
Kenwoods are notorious for this, pull your deck out. i 80% promise that all of you have a ground or a blown speaker,
you need to take the deck out and unplug the harness,
with a test light NOTE!! ALWAYS USE A COMPUTER SAFE TEST LIGHT, YOU DONT WANT TO BLOW YOUR COMPUTER!! hook up the red side to the an exposed part of the yellow wire on your sterio wire harness, it has to be connected to the actuall wire inside for it to work if you have to strip a peice of this off do so but tape it back up when your done. probe the white, grey, green, and purple wires with the tip of the test light, and i almost guarentee you will find a wire that lights up your light, the color of wire indicates which speaker you blew.
white-left front speaker
grey-right front speaker
green-left rear speaker
purple-right rear speaker,
do both of the same color wire,
Aug 05, 2009 | Kenwood Car Audio & Video
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Stereo will not operate correctly
did you try running a ground wire from the case of the deck to the battery,just for testing?
Feb 04, 2008 | Kenwood KDC-MP435U CD Player
Kenwood KDC-MP333 in-car head unit
HAVE YOU PRESSED THE RESET BUTTON ON IT ALL KENWOOD RADIOS HAVE ONE
Oct 23, 2007 | Alpine CDA 7893 CD Player
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Car Audio & Video Logo
205 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
