Program timer not working - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
In such cases if there is no fault of the power wiring to the timer then the timer must be replaced.
Posted on Jan 02, 2013
What does a flashing "on" mean? The timer does not work as programmed.
The attached page is long but will show you how to reset and program your wall switch timer
May 27, 2014 | UPM Programmable Wall Switch Timer
Installed lw60418 timer, timer works but lights do not go on.
1) Copy following link for correct wiring and programming.
Always reset digital timers before programming to clear stray memory:
Timer must be wired correctly.
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
2) Each ON setting requires OFF setting, and days for each must match.
This timer does not show rating for inductive loads such as CFL or LED.
Timer is rated for resistive loads such as incandescent bulbs.
3) Buy Intermatic ST01C timer, or GE 15312 timer for inductive loads.
http://waterheatertimer.org/ST01C-program.html
4) Add comment and describe situation in more detail, Dec 2013
Dec 30, 2012 | Hardware & Accessories
I have an Intermatic E1600 Digital Wall Timer and I cannot remember how to reset it to an earlier time...and I have misplaced the instruction manual. Any help you can give me is appreciated! Steve
You probably have Intermatic Ei600 which is 5-year warranty timer that uses CR2 battery, and has same programming steps as lighter-weight Intermatic ST01C timer.
Open following links to identify timer, read ez set instructions, and download manual.
http://waterheatertimer.org/pdf/Intermatic-ei600c-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
The timing programs for Ei600 and ST01C timers remain in memory indefinitely even if battery goes dead. If you re-program current time and date, the original programs are still there.
If timer stopped functioning, then replace battery. Usually with battery replacement, the timer must be re-set which clears all programming.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Intermatic EI600LAC Electronic Timer
It does not turn off why
Unknown if this is new ST01C timer, or older timer that worked before and stopped working.
Add a comment with more information if needed.
Timer can be defective. Battery can be low. Wiring is wrong. Timer programming has overlaps and conflicts. Program 1 is set but program 2 is not set. No programming is set. Short circuit on lights.
I suggest change battery and reset timer, then reprogram timer.
Write out schedule beforehand to avoid conflicts and overlaps.
Program 1 is ON and program 2 is OFF. Program 3 is ON and program 4 is OFF. etc.
Open following link for re-set and programming illustrations, plus battery replacement and wiring diagrams:
Sep 10, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Need to know how to manual over ride intermatic lighting programable timer.
The Intermatic battery-operated timer series override button is either the on-off button or push in the door that acts like a switch and pushes on-off button.
The manual override reverses the programming, and then programming resumes at next set point.
So the override does not disengage timer programming.
Open following link for ST01C timer manual and ez programming.
http://waterheatertimer.org/ST01C-programming.html
Add a comment for more help.
Upvote the help.
Jun 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
HOW DO I PROGRAM THIS TIMER
Open following link to identify GE timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
GE 50462 is vacation timer with preset program tabs, and cannot be programed to turn on-off at selected times
Upvote the help.
May 27, 2011 | GE 50462 7Day Random Vacation Timer
Do not know how to set timer DT300 for Lights
Hi
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Thanks.
Dec 27, 2010 | Audio Players & Recorders
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Oct 12, 2010 | Intermatic Hardware & Accessories
I programmed the timer to go on and off at a specific time and it doesn't work. The time of day and the date are working fine. It is only programmed for one light.
To program the ST01C:
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
1) Manual has troubleshooting. Since ST01C is battery operated, it will not work on loads farther than 100 feet away from timer. If a wire is buried underground, this can interfere with operation. Other electrical devices can interfere with timer operation.
2) Solution:
a) Check for interference issues listed above.
b) Press MODE and make sure it is set to AUTO. If timer will not enter AUTO then no program has been set.
c) Re-check your programming as shown in step 6 of manual. Remember timer offers 40 programs. To set Program 1 >> 'on' time has to be entered and saved for Program 1 >>> and then 'off' time has to be entered and saved for Program 1. And then press MODE and set to AUTO.
Sep 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
