Question about Whirlpool Washing Machines
Program timer of model AWT 55S - Whirlpool Washing Machines
  • Whirlpool Master
  • 17,129 Answers
Please check for support from Whirlpool support
Posted on Jan 02, 2013
PrintMaster 2011 Platinum <3.0.70> encountered
Hello, I had the same issue, I found this article http://support.encore.com/technicalsupport/kb.aspx?kb_id=1250&product_id=2643 It pretty much says that your regional setting is not set to English United States. Changing that will resolve the issue. Under Control Panel > Regional Settings.
Dec 17, 2010 | Broderbund PrintMaster Platinum
I installed Printmaster 2011 platinum on my pc. Everything went well until I tried to print my project. I have an error message everytime that says: Printmaster 2011 Platinum 3.0.70 encountered the...
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00"
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224)
at java.lang.Float.valueOf(Float.java:388)
at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982)
at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386)
at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103)
at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
Oct 22, 2010 | Broderbund PrintMaster Platinum
How to get no. Of pixels from given image through java
try this code
import java.awt.image.PixelGrabber;
import java.awt.Toolkit;
import java.awt.Image;
class getpixel2
public static void main(String args[]) throws Exception
Image image = Toolkit.getDefaultToolkit().getImage("D:\\one.jpg");
if(image==null)
System.out.println("NO FIle");
PixelGrabber grabber = new PixelGrabber(image, 0, 0, -1, -1, false);
if (grabber.grabPixels())
int width = grabber.getWidth();
int height = grabber.getHeight();
if (isGreyscaleImage(grabber))
byte[] data = (byte[]) grabber.getPixels();
else
int[] data = (int[]) grabber.getPixels();
for(int i=0;i<data.length;i++)
int r = (data[i] >> 16) & 0xff;
int g = (data[i] >> 8) & 0xff;
int b = (data[i] >> 0) & 0xff;
System.out.println("(R,G,B)=("r","g","b")");
public static final boolean isGreyscaleImage(PixelGrabber pg)
return pg.getPixels() instanceof byte[];
} import java.awt.image.PixelGrabber;
class getpixel2
if(image==null)
else
May 15, 2010 | Computers & Internet
I have Windows 7 and just installed PrintMaster 2.0 Platinum. I cannot print anything. here is the error message. PrintMaster 2.0 Platinum encountered the following error: java.lang.NumberFormatException:...
I had the same problem. If you are using a french version of Windows, try to switch your regional settings to "English US". It worked for me. Every time we use an English software on a French version of Windows, we have compatibility problem... ;)
Good Luck!
Dec 21, 2009 | Broderbund PrintMaster Platinum
Jnlp code for the java program
From command prompt: You can also launch an application from a command prompt by typing javaws jnlp_url where jnlp_url is a url to the jnlp file of the application. Go to Start > Run > type "cmd". A command prompt window will appear. Type "javaws url_of_jnlp"
May 28, 2009 | Microsoft Office Word 2007 Upgrade Version...
I am developing one java related application.In this there are three places place1,place2 ,place3 ,,if i'm click the place 1 ,in text box the text should come ilike ''place1 text.After that, when i click...
public class MainWindow extends javax.swing.JFrame {
public MainWindow() {
initComponents();
textField1.setText("");
.....component initialization function
private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
textField1.setText("Place1");
private void jButton2ActionPerformed(java.awt.event.ActionEvent evt) {
textField1.setText("Place2");
private void jButton3ActionPerformed(java.awt.event.ActionEvent evt) {
textField1.setText("Place3");
* @param args the command line arguments
public static void main(String args[]) {
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new MainWindow().setVisible(true);
Mar 24, 2009 | Computers & Internet
About java swing..
Hi, if you have a specific query about java Swing, I can try to help you. Please find a small java code with using swing as example.
import java.awt.BorderLayout;
import java.awt.Font;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import java.awt.event.WindowListener;
import javax.swing.AbstractAction;
import javax.swing.Action;
import javax.swing.ButtonGroup;
import javax.swing.ImageIcon;
import javax.swing.JButton;
import javax.swing.JCheckBoxMenuItem;
import javax.swing.JFrame;
import javax.swing.JMenu;
import javax.swing.JMenuBar;
import javax.swing.JMenuItem;
import javax.swing.JRadioButtonMenuItem;
import javax.swing.JToolBar;
public class ToolbarDemo extends JFrame {
public static final String FontNames[] = { "Serif", "SansSerif", "Courier" };
protected Font fonts[];
protected JMenuItem[] fontMenus;
protected JToolBar toolBar;
public ToolbarDemo() {
super("Toolbars & actions");
setSize(450, 350);
JMenuBar menuBar = createMenuBar();
setJMenuBar(menuBar);
setVisible(true);
protected JMenuBar createMenuBar() {
final JMenuBar menuBar = new JMenuBar();
JMenu mFile = new JMenu("File");
ImageIcon iconNew = new ImageIcon("file_new.gif");
Action actionNew = new AbstractAction("New", iconNew) {
public void actionPerformed(ActionEvent e) {
System.out.println("new action");
JMenuItem item = mFile.add(actionNew);
mFile.add(item);
menuBar.add(mFile);
toolBar = new JToolBar();
JButton saveButton = new JButton("Save");
toolBar.add(saveButton);
getContentPane().add(toolBar, BorderLayout.NORTH);
return menuBar;
public static void main(String argv[]) {
new ToolbarDemo();
Thanks and Regards,
Supa.
Mar 10, 2009 | Microsoft Internet Explorer 7
Need cord for Shure 55S microphone
See the Shure website for the answer at:
http://shure.custhelp.com/cgi-bin/shure.cfg/php/enduser/std_adp.php?p_faqid=1012
Mar 09, 2009 | Shure 55SH Series II Professional...
AWT PROBLEM IN JAVA.
its runing the program.it didnt has any problem
Aug 12, 2008 | Computers & Internet
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
