Have a model gz-1002b-e1 it's not working .. when turned on with remote the sleep light keeps flashing and we can't turn it off have tried turning the power off but still keep flashing
3 Suggested Answers
SOURCE: manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Posted on Sep 06, 2008
SOURCE: My remote control will not turn on. The timer
take your chellphone and open the camera,then take the control and push any button in front of the chellphone.if the remote is ok you see a light blinking.if you didnt see the light the eye of the small plate have the problem.
Posted on Dec 09, 2009
Manual for mistral air conditioner model GZ-1002B-E3
http://www.service-aerconditionat.ro/Manual_Aer_conditionat_Galanz.pdf
Jun 29, 2013 | Heating & Cooling
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have just taken delivery of an air conditioning unit using a GZ-1002B-E3 IR remote control that does not work. How do I get a new remote control?
This is a new unit and you must make a complaint to the dealer immediately to replace your unit. Make sure that the battery is good , the position of the battery is correct and the remote is aimed at the unit.
If not ask for replacement, file a complaint as a new unit has a warranty.
Feb 17, 2011 | Kitchen Ranges
SONY HDTV-LCD MODEL - KDF-42WE655 turns itself off. Lamp light indicator flashes red. Should I attempt to reset ? It is approx. 4 years old
I'd wager that somewhere in the menu settings, there is a "Sleep Timer". Check the menu for the sleep timer, which turns off the TV after a set length of time. Also, check your remote, there might be a "Sleep" button that would do the same thing, press it multiple times until it reads "Sleep: Off" or something similar.
Dec 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My remote control will not turn on. The timer function comes on but nothing happens. model GZ-1002B-E3 mistral MSS2.6
Dec 09, 2009 | Hitachi RAS-09UH Air Conditioner
My Proscan 19LA20Q Keeps going to sleep mode after my sister touched something on the remote. The Blue screen and the source flashes on for a few seconds then the light goes orange and the screen goes...
ur sister possible turned the sleep mode on.......check on ur remote that is is off......if this problem persist u have to call service to fix ur problem
Nov 20, 2009 | Proscan 19LA20Q LCD TV
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Manual for Akai reverse cycle airconditioner remote control
Jun 08, 2008 | Heating & Cooling
Heating & Cooling Logo
248 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
