Lg ht352 dvd system turns on and off but can not read/sense radio,aux,dvd player and the usb. When you switch it on,Sshheee sound is audible from the circuit even if the speakers are not connected. yo
I used to hit it slightly on the sides when it does not respond whilest it's on and eventually it will play but this time it does not want too.
SOURCE: Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Posted on Oct 05, 2007
  • 3 Answers
SOURCE: Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Posted on Jan 03, 2009
SOURCE: Sound problem with LG LHT754 theater system
Hold down "2" on the remote simultaneous to "stop" on the receiver. In a couple of seconds you will see something appear on the display. OPO-63? Anyway, repeat the process again when you see that. The system will reset. This will also take care of the inability to switch to AUX or Ipod.
Posted on Jul 26, 2009
SOURCE: LG wireless dvd reciever system
Hi, I had the same problem, it seems to be a design error of LG or a typical problem with some component in the wireless transmitter. It is basically caused by the transmitter heating up, leading to a clock drift with the result of the receiver losing the signal. I tried to cool the transmitter in the fridge before using so it will run for about half an hour before producing this error (depends on the room temperature as well). My solution is to remove the plastic case of the transmitter unit and place it in a cool place where it does not catch heat from other devices. Without the case it does not overheat and also takes less space, just be careful if you have children. I placed the naked Tx unit behind the TV so it does not matter. Hope this works for you as well.
Posted on Aug 31, 2009
SOURCE: NO SOUND From JVC TH-S5 Home cinema system
I know this is an old topic however someone somewhere might benefit from this feedback. I purchased the JVC TH-S5 service manuals from ManualsParadise.com and after metering all the supplies as 'OK', I then focused in on the 'common' lines associated with the two onboard power amps IC's (STK413-400) and found that they were missing a bias supply. This is derived from the onboard 40v Supply 'dropped' down by a 47 ohm resistor R2702 (rated 1/4 watt but advised to make this at least 1/2 watt). The resistor was found to be open circuit i.e. a very high ohmic value. Looking at the circuit diagram again, I would feel that this is going to be a common issue with this unit.
Mike.The.Cork
Posted on Sep 12, 2009
What is the universal remote code for lg LHT854
The applicable code would be in a compatible universal remote control. All universal remote controls do not contain all possible codes.
Sep 25, 2017 | LG LHT854 Theater System
I cant get my lg ht303su system to play sound from my television how do i do this?
Connect the RCA cables ( red, white, yellow cables) to the necessary jacks o the DVD player and tv..the DVD player should have an "AUX" input amongst the other inputs eg DVD,USB etc..this allows you to play sound from the TV through the DVD HT
Jan 05, 2013 | LG HT303SU Theater System
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
Jul 09, 2017 | 2002 Buick Rendezvous
When I connect my Sansa mp3 player to the single CD audio system (using the Hyundai usb connector), with the cd\aux on and cd selected, it switches to aux and the screen reads "CONNECTED" but I get no...
This sounds like you do not have full usb functionality and it is diverting to the aux input. when aux is used you have to control the play and sound etc from the actual mp3 player and not the audio controls
Jul 31, 2010 | Hyundai Santa Fe Cars & Trucks
I have an LG dvd home theater system model no: HT302, plays everything bt no sound. So i've been tring to get to solve the problem bt still nothing comes right, so now i'm looking for pc board for these...
common the capacitors in the switch mode, use quality 105Degree smps caps.
the faulty caps are usually swollen, replace all while you have it open.
Jul 30, 2010 | LG HT302SD Theater System
I have a jensen uv10 and cant get the radio on the usb plugin to read my ipod so everytimei start my car i have to replug it in the usb any ideas????
connect it to the aux 1 or aux 2 inputs. buy the adapter at walmart in automotive section were the dashkits rca jacks are it should be $5
Mar 03, 2010 | Jensen VM9510 Car DVD Player
I CANT GET THE TV SOUNDS ON THE PLAYER
Do you mean from a tv program? You have to have the device such as a cable box or sat go through the dvd player by an input cable such as composite, componet or through hdmi. Then select the aux or aux input using the input buttons.
Dec 13, 2009 | LG LHT854 Theater System
No signal when in aux mode
if you want surrond sound you will have to switch the white/red rca jacks for a digital or optical input cable
and all will be well!
Please rate answer to help keep this site free!
Jan 02, 2009 | Samsung HT-Q100 System
Feb 16, 2008 | Audio Players & Recorders
106 people viewed this question
 Grubhead
Grubhead
