ERROR
Resource Conflict - PCI in slot 03
Bus:06, Device:04, Function:00
(Repeated three times, only Function changing to 01, 02, and 03)
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
I was on this forum because I was having the same issue with a Toshiba A75 "Laptop", and I tried everything on here and on other forums and no luck. I actually just accessed the integrated wireless card panel from the bottom and removed it from its slot and disconnected the wireless wires connected and put it back on. So this has worked for me and my machine post perfectly now. Good luck to all and I hopefully this will be helpful too you.
SOURCE: Al encender mi ACER Aspire
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
SOURCE: when starting the laptop acer
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
