Question about LG WFT1071TP Top Load Washer
How to operate lg fuzzy logic WF-F6702PCP - LG WFT1071TP Top Load Washer
  • 210 Answers
SOURCE: PE error code on LG WF-T653A
PE is a pressure switch problem. Could be a bad switch or it could be that the hose is plugged. The switch looks like a diapharm switch and is located on the main board. It has a black hose that connects under the bottom of the tub. See if that end is clogged. Otherwise you may need a new switch.
Sgt 48
Posted on Jun 02, 2008
SOURCE: LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Posted on Oct 10, 2008
  • 22 Answers
SOURCE: LG fuzzy Logic 5.5 WF T552
check drain to see if plugged. if it can't spin water out, it will shut down.
Posted on Oct 21, 2008
  • 6 Answers
SOURCE: I have a Brand LG
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Posted on Dec 20, 2008
  • 4 Answers
SOURCE: I'm using LG Fuzzy logic 6.5kg WF-S6607TC.
Check the lid cover. At the edge, there is a plastic housing some sort of a magnet. This is the magnetic sensor for lid cover open protection.
If the magnet is not there, place a magnet at the position on the washer where the housing will come in contact with the washer when lid is close.
Posted on Sep 09, 2009
Lg fuzzy logic 4.0kg wf-402a wont drain
First things first, check the pump / hoses for blockage, check if the pump is operational, check outlet hose for kinks.
Apr 11, 2015 | LG Washing Machines
Lg fuzzy logic manual wf
You can download the manual on LG's website at LG.com/ca_en/appliances
Aug 29, 2014 | Washing Machines
Hi I have a LG Fuzzy Logic 8.2kg WF-8071TTP washing machine. It washes but does not spin dry. Please heelp
may sound crazy, but sometimes the water pump gets clogged and does not operate, so will not spin. safety feature, I guess.
Try cleaning out pump.
Bruno
Aug 06, 2014 | Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Apr 07, 2010 | LG Washing Machines
LG FUZZY LOGIC
Sep 22, 2008 | LG WFT1071TP Top Load Washer
LG WFT1071TP Top Load Washer Logo
27 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
