Question about Jura Capresso Impressa X90 Espresso Machine
Jura Impressa X90 Espresso Machine acting up
Trying to get my X90 to work properly. I got it in broken state, and i've done a complete "service" on it, lubricating all O-rings, connections etc. Descaled the frother nozzle, cleaned the Solenoid for frothing etc. The machine has no error codes and brews Coffee, but not stable. If it's the first cup of Coffee you make on it since a while, almost nothing goes into the cup - It only goes half way into the brew and then spits it out in the waste container. If you immediately brew another cut afterwards, the content goes into the cup. It seems impossible to use ground Coffee on the machine, i place a spoonful in the funnell and it only goes some part of the brewing process and stops. I cannot see any leaks, it's just like it starts brewing and then stops for some reason. I cannot seem to find any pressure transducer/regulator on this unit - And idea of what could be wrong ? TIA!
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
protek480
  • 1723 Answers
SOURCE: I have a Jura S9A that is about 2 years old,
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Oct 10, 2009
  • 13 Answers
SOURCE: How do I disassemble and clean the brew unit motor
I have some good instructions I downloaded from www.kaffeestudio.com . They are in German, but with many pics. If you are technically adept, then it is really no prblem. You should put in new o'rings and lubricate with the food grade silicon grease before reassembly, otherwise it won't be long before you are doing it again. Give yourself about 3 hours to perform this task the first time. One thing to remember. The cleaning tablets tend to strip the lubrication from the brew units, subsequently binding up the brew unit, sometimes tearing the o'rings and giving the malfunction 8. Plan on this being an ongoing maintenance exercise. Plan on at least once every year or two to have to do this.
Posted on Oct 18, 2009
  • 5 Answers
SOURCE: Have reassembled the Brewing unit - am now getting Malfunction 8
oh dear that is too long without a coffee ;-( I was wondering if you could share your knowledge on how to dismantle the Jura coffee machine, i have a E85 and i need to remove old coffee sludge that is causing my problems. do i remove the back of machine?
Posted on May 05, 2010
ftw1952
  • 10319 Answers
SOURCE: No coffee will comeout of
back flow problem in the water feed valve. I never had to service one of these brands although I am sure the valve is frozen or clogged up
Posted on Aug 22, 2010
Jura Impressa X90 doesn't give water or coffee. Keeps saying: fill system
Hello, make sure the magnet in the water tank moves freely, sometimes it gets stuck with deposits, its a small black rectangle near the base. if its not free, you need to put some descaling solution it the tank to clear it.
Jul 03, 2012 | Jura Capresso Impressa X90 Espresso...
Looking for service manual for the Impressa X90. trying to figure out the routing on the steam knob hoses inside of the machine. I wan to make sure that I have them set correctly.
there is no such a thing as service manual only Capresso own repair pesonnal can see a repair manual,Capresso do not want anyone else to touch the inside of the machine,they want you to contact them and send in the machine
let me know if you can find any other solution
Aug 25, 2011 | Jura Capresso Impressa X90 Espresso...
I lost my tray for mug
You can probably order it from Jura Capresso - most, if not all, stores will not carry the individual part:
CALL Jura's toll free HELP LINE: 1-800-767-3554 Monday - Friday 9AM to 9PM and Saturday 9AM to 5PM Eastern Standard Time
-Tha Mp3 Doctor
Jan 15, 2009 | Jura Capresso Impressa X90 Espresso...
JURA X90 ESPRESSO MACHINE LEAKS UNTO COUNTER
inside the machine a rubber tube is broke or loose causing this leak!
Dec 09, 2008 | Jura Capresso Impressa X90 Espresso...
Jura impressa x90 keeps beeping
call the 'Coffee Boss"  in North carolina.  you will have to find him on Google. his name is heinz and he is the guy that Jura uses when they can't fix it.  He's fixed my x90 3 times.
good luck
Oct 13, 2008 | Jura Capresso Impressa X90 Espresso...
Jura Capresso Impressa X90 Espresso Machine Logo
109 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
