I HAVE A CARTEL CTC21-99 TV KEY MESSAGE TOP LEFT CORNER TRIED 111 000 999 ETC NO LUCK
5 Suggested Answers
MrBob84
  • 90 Answers
SOURCE: Blurry tlurry in the top left corner ext
Your convergence has drifted off. All CRT tech is high precision work, and needs touchups now and then.
Or your conv ICs could be out, and needing to be replaced.
Mr Bob
Posted on Feb 03, 2008
universalfoe
  • 34 Answers
SOURCE: a block box appears in the top left corner of my Sony TV
Check your Menu for Closed Captioning, Make sure this is turned to off in Audio Menu
Posted on Dec 15, 2009
jcameo7270
  • 675 Answers
SOURCE: We have an 'AV-2' sign appeared in the top left
you should be able to hit the display buttton on the remote to get this to go away
Posted on Jan 08, 2011
sharcnet
  • 2130 Answers
SOURCE: My garmin nuvi 660 boots
Common problem with this model. Defective touchscreen. Please see this link for more information. Too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Aug 25, 2011
Chunghop universal remote RM-306E code for lg tv
if you are using CHUNGHOP RM-306E this would be applicable for all brands of TV..
1) Turn on the TV
2) Press S button (top left corner) until red light on
3) Press Green button (power button top - right corner)
4) press volume + button (blue at the middle on the left) until the volume signal display on the TV
5) press S button again
Now you are set..
Test the remote function it should be working now.. if not repeat the steps above until you got it working..
Good luck..
May 07, 2014 | Televison & Video
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
Black screen with a little white line in top left corner. wont boot in any mode
that in fact is called the "prompt" or "cursor prompt" sounds like you havent got an operating system,Try F2 whilst booting to go into bios pages to configure boot sequence.Navigate with "tab" and arrow keys,,,save an exit ,,or restore to factory defaults etc--good luck!
Davey Snake!
Oct 25, 2010 | Compaq Computers & Internet
Sony bravia always has AV etc in top left corner.
top right hand corner i+ button press it till it goes,should do the trick
Jan 29, 2009 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
Input number displayed in corner (V-1, V-2, etc.)
Believe it or not, sometimes things just randomly happen. Remote controls operating using infrared light and coded commands, and sometimes sheer dumb luck results in the TV deciding it's gotten a remote command. This is sometimes more frequent in homes where CFL replacement lamps are in use. The way they work can sometimes cause interference with some remotes, and can confuse the TV as well.
Jan 28, 2009 | JVC AV27F476 27" TV
Red Padlock displayed in top left corner of a blue screen.
try this with the tv off simultaneously press and hold volume minus on the tv's front panel and clear on the remote control for 5 seconds then enter a new password good luck
shaun
Jan 17, 2009 | Televison & Video
Loss Sync
According to SharpUSA the problem with the "Loss of Sync" error message is that (most probably) the cables (between the box and the display) are not connected properly (so remove and reconnect them carefully, on both units) or a cable is defective.
Also, after you reconnect the cables try turning on the unit, if no success then depress the "clear" button on the external box (under the door on the front and on the bottom left and try turning on the TV again).
It is, most likely, that the cables are not seated properly. Reseat the cables on both the display and the external box.
Hopefully, this will clear the problem
if still does not solves your problem just replace all the cables connected between .u can get the new cables at radioshack web site.just place an order they will provide you. thanks.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Problem with my Goodmans 2065TS
Hi.
Sounds like your tv has gone in to service mode.
Try doing this (BUT DO NOT PRESS ANY OTHER BUTTONS)
  • Select pr. number 91
  • Adjust sharpness to minimum and exit all menus.
  • Quickly press the key sequence : RED - GREEN - menu
  • The software version is displayed beside the word Service, e.g. “ SERVICE V1.00A”.
  • To exit SERVICE menu press menu key or Std By key.
  • http://dysonmanuals.inc.io/
    Oct 26, 2007 | Goodmans 2065TS 20" TV
    How can I remove the little 'green key' in the lower left hand corner of the screen
    Try pressing the "F" or function button and hold while pressing the Mute or "M" button at the same time. Good Luck
    Jul 27, 2006 | Apex Digital AT1314DV 13 in. TV/DVD Combo
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
