Since installing adsl on my computer my brother mfc -257cw printer does not work
Will not print since installing ADSL on my computer
    Problem Solver:
  • 17 Answers
Check the cables, there is no link between your internet and printing, probably just a Cable that fell out or is mis-wired.
Posted on Jan 02, 2013
Patrillica
  • 141 Answers
SOURCE: install Brother MFC 3100C 5in1 printer,fax,scanner,copier,pc fax to my computer.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=mfc3100c_us
Follow this link and step 1 select driver...
step 2 select your OS....
step 3 select the language....and click search.
On the next page you'll see, in FULL DRIVER & SOFTWARE, more information, click on this and download the driver.
Posted on Apr 05, 2008
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
  • 55 Answers
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Posted on Jun 30, 2009
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
SOURCE: I have a brother mfc-295cn printer that won't print black
Mine wouldn't print black either on Plain Paper, but if I changed the settings to Transparency Paper type it would. Hope this helps
Posted on Dec 14, 2010
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
I have a new MacBook Pro and cannot get my Brother printer to work with it. The computer recognizes the printer but does not print.
Did you install the Mac driver for MFC? The MFC comes with driver for windows and Mac. Place the Mac Driver disk to DVD slot and run the installation for your MFC printer. Follow the instruction to complete the installation.
When you try to print something, make sure the MFC printer is selected.
If you've done all of this and still not able to print, please turn off your MFC, wait 15 seconds and turn on again to see problem solve or not.
Hope this will help. Thanks for reading.
Jul 19, 2011 | Brother MFC 420CN All-In-One InkJet...
Printer will not fax I have dsl modem for computer
Hi
If you have ADSL modem for the internet, and same line you connected with Fax then you will need to ADSL splitter to split your adsl line, get the ADSL splitter in market. in splitter you get one male pine or two female pine, male pin you connect the main switch where the connect is come, one female is ADSL there your connect your modem, and other female pin you connect you fax and try. your fax and internet will work both at a time.
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Wireless printer.Lost Manual. Have disk with drivers. Have networked 3 lap top computers with desktop through netgear adsl/router (single unit) and are able to successfully connect to the internet. I now...
Should be able to set all computers to default to Brother printer in the preferences section of the printer control panel ( look in 'control panel' of computer). You ca n also download manual from Brother website. Just type make and model + word Manual into search engine, and it should throw up the appropriate link.
Sep 27, 2010 | Brother HL-2170W Laser Printer
Brother (MFC-7340 FAX, Scan, Print) - Can send FAX...
Be sure to have a noise filter on the ADSL line so the line quality is good enough to send and receive faxes.
May 20, 2010 | Brother MFC-7340 All-In-One Laser Printer
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
2 printers not printing black
No, it could be a problem with the drivers for the printers. Please follow the link below to un and re install the drivers on your computer.
Installing Devices on PCs and Laptops
May 08, 2010 | Brother MFC-5460CN InkJet Printer
Cannot get printed faxes
the phone line needs filtering off ,because your fax machine is an analoque device
Mar 26, 2008 | Brother MFC-7820N Laser Printer
jasbo
jasbo
