Question about Genie Garage Door Opener 1-Button 9 Or 12-Dip Switch Compatible Remote - Model GT-912
Remote board #25968A, R1A not functioning, need schematic!
Remote not functioning, LED comes on but nothing else happens, need schematic to further troubleshoot.
Remote quit working
After replacement of batteries, universal remote controls, need to have setup with the device, using device codes. Just find out the setup code for Admiral TV, and setup the remote with it. Setup proceedings, and code lists are given in detail in this site. 'Electro-help' is the site name. Type in 'electronicshelponline.blogspot' in your browsers' search box, and click search. It is a blogspot site in English language. Pull up older posts there. You can get all details you want from here.
If you want further assistance from me, inform me by Fixya.
Jun 23, 2012 | RCA RCRN04GR Remote Control
Pioneer pdp-r05e is not working properly
First if no remote functions unplug set for a while and replug it--may allow set to reboot.
Let me know what happens or if need further help.
Apr 02, 2012 | Televison & Video
No communication between receiver and remote
amandaharwoo,
The first thing I would do, if you haven't already, is replace the batteries in the remote. The lights will still illuminate if the batteries are low but won't perform the remote functions. If that doesn't fix the problem, the remote may need to be readdressed to the receiver. I have provided the steps below. If you have further problems, please respond to the site.
  • Remote: All Other Remotes
    1. Go to System Info screen
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button
    5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DSIH Network
Jun 13, 2010 | DISH Network 721 DVR Remote Control
Samsung CXM1374 TV/VCR COMBO. The original rmote no longer functions. Changed batteries but still no functions work. Does remote or TV buttons have to be activated to reprogram?
you need to open the cover of your remote control..visually inspect the PCB for any loose connections/cracked board specially the battery terminals...solder any loose connections and if nothing happens replace the crystal oscillator from the remote control it is a square,color orange sometimes blue with a label on it its clock speed in MHZ. it is available at electronics supply store..you can use the camera of your cellphone to test whether the remote is working by just pointing the camera to the LED at the top of your remote once you press a button from the remote the LED should lit...means your emote is working...3rd test the LED/infra red if it is not busted..remove the LED INFRA RED from the pcb and using a multitester analog supply.set the tester to X1 range then supply the terminals positive negative with the test probe there should be a continuity connection and the LED should be lit.
May 20, 2010 | Televison & Video
52PFL7403D/F7 remote does not work with my TV
Hi
First thing to do is check your remotes by aiming them at a camera or the camera on your mobile phone then pressing any button you should see the led on the remote light up white, If this happens then your remotes are ok and you would then need to look further into the problem.
I would suggest the remote sensor in the tv being short or you may need a replacement AV board (the one that has the inputs and scart sockets are on )
Hope this info helps
Apr 05, 2010 | Televison & Video
Insignia remote wont work
sandraw, try disconnecting the tv from the ac outlet for a few seconds(20-30) and reconnect and then try your remote, in your description you do not mention if this remote is the original equipped remote that came with the tv, but i am guessing it is since it is a fairly recent model. You also don't mention if the tv works with the function keys(pow,volup/dn,chn up/dn etc)this also might point out to wether there is damage to the ir preamp board, a bad preamp board would also impair the overall function of the remote as well as the customer selection from the built in function keys. hope this helped and please leave your positive feedback, if i answered your question.thanks!
Aug 28, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Trying to install a remote start & keyless entry. I need to know where all the wires from the ignition harness go too???
First you will need to research your vehicles under-dash wiring schematic to identify your object wires, color code and function. The schematic may be found in a Y.M.M.(year,make & model) specific, electrical wiring manual. A related search on the internet, or at your local auto dealerships parts department. Then cross-reference and record your vehicles color coded leads to the remote starts color coded leads with respect to their function.
Hope this helps,,,Good luck
Aduz
Mar 27, 2009 | Crimestopper CoolStart(TM) 2-Way Remote...
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Genie Garage Door Opener 1-Button 9 Or 12-Dip Switch Compatible Remote - Model GT-912 Logo
27 people viewed this question
Top Genie Televison & Video Experts
ray gallant
Lex Landa
Lex Landa
Level 1 Expert
Are you a Genie Televison and Video Expert? Answer questions, earn points and help others
