Question about Carrier Furnace Control Circuit Board Hk42fz011
FURNACE LITES UP RUNS FOR 2 MIN. SHUTS OFF GAS.PAYNE
    Master:
  • 571 Answers
Carrier had a recall years ago on the HK42fz004 & I believe the 008 models because of intermittent problems like yours. Sounds like you need a new board
Posted on Dec 06, 2013
  • Marv ANDROSCHUK
    Marv ANDROSCHUK Dec 21, 2015
    Try putting new batteties in the programable thermostat first
3 amp fuse blows when call for gas after pilot runs for 30 seconds
check the blower motor for seized of burnt out. Fuses blow because of excess current draw and in this case if the fan is not starting everything will stop. The gas will be set so that if the fan is not running the gas will not be allowed to turn on
Nov 21, 2014 | GE Carrier Bryant Payne 1/3 Hp 115v Blower...
I have a White Rodgers 50E47-843 Ignition control, my gas furnace gets the call for heat and the exhaust fan starts and runs for 1 min before the LED lights yellow for 2 seconds and then starts the hot...
A certain sequence of events has to occur to start normal operation. My furnace would start the stack blower which would then run forever without the furnace starting up. The service tech replaced the stack blower controller and the ignitor to get things running right again. Remember that some stages of startup are temperature dependent. For example, the burner has to heat the bonnet enough to close a thermal switch and turn on the main.blower.
Oct 26, 2013 | Heating & Cooling
Ducane furnace gas burner runs one minute shuts down
If this has an Hsi Ignition its time to have a tech check it out and replace
Feb 13, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
Lites up good runs about 15 min fire goes out put your finger over the air hole and it lites back up remove your finger it goes out
The gas/air mixture is off and the burner is getting too much air...
You did not list or it did not come up with what type of (make/model) unit you are working with, so I cannot tell you how to adjust it... all are very different...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 11, 2011 | Heating & Cooling
I have a Payne gas furnace that is 23 years old. The unit ignites, blower motor runs for 3-4 minutes, shuts down, comes back on for 10-15 seconds turns off and comes back on for 10-15 seconds- any help?
You have a bad fan limit switch find the one that looks like yours and has the same length tube on it and after that there all universal its real simple to replace just 4 wires 2 low voltage on the limit side and 2 high voltage on the fan side instructions will come with. To remove the old one just take off cover remove screws and wires and pull it out where the wires connect you will see little metal slots above or below the wire just push it in with a little screw driver and pull the wire out. Here is a link to a web site I buy parts from. Their real fair on price and fast with ship
http://www.hvacpartsshop.com/search.aspx?find=fan+limit+switch
Hope this helps.......
Nov 18, 2010 | Heating & Cooling
Furnace blower does not turn on
Pat, look for any way to add a few drops of 3-in-1 electric motor oil to the shaft ends. You may find a few small plastic removable plugs where you can drop a few drops into. Get the numbers off the oval shaped capacitor and replace it as soon as possible. Inspect all wires and sand all contacts one at a time to make sure wires go back on original spades. If it continues, you may need to replace the fan relay. Good luck to you!
Feb 25, 2010 | Heating & Cooling
Furnace runs OK, but blower runs again a few seconds later
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Mar 11, 2009 | Carrier Heating & Cooling
Gas furnance won't stay lit.
have a furnace man take a look it sounds like the itermitter control
Feb 05, 2009 | Goodman GMS80904BNA Open Flame Mid-Size...
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Carrier Furnace Control Circuit Board Hk42fz011 Logo
392 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
