Question about Nokia 2730 Cell Phone
Frequent switch off even if the battery is full
    Problem Solver:
  • 17 Answers
Check the battery contacts for dirt or loose contact. Maybe there is an intermittent contact somewhere in the phone, that can lead to it switching off
Posted on Jan 02, 2013
My 4 year old Toro Timecutter is hard to start & keeps cutting off
The battery and charging system only start the engine. They have no affect on the engines running. The engine runs off magneto ignition which requires no outside power source. Check your battery for full charge with a volt meter. !2.6 volts is 100%. If the engine is hard cranking with a battery at full charge it could be valve timing, valve clearance, or the compression release not operating properly.
One other possibility would be the carb flooding an filling the cylinder and crankcase with fuel but you would have noticed smoking after you got it started had the cylinder been full of fuel.
I would start diagnoses by checking the valve clearance and check the flywheel key.
Aug 24, 2014 | Toro Garden
My nokia x3 cannot switch on..even not charging
First of all pl check the battery coz Noia Bl-4ct may open its connector frequently and if possible change good battery .If the problem still persist contact mobile repairing shop.
Jul 21, 2011 | Nokia X3 Cell Phone
Toshiba SATELLITE A205-S4577 CORE 2 DUO INTEL. When conected to the external power supply the notebook suddenly interrupts its functioning and it is necessary to do a hard power off, becouse nothing more...
- possible problem with the AC power supply
- try using a different AC adapter. if issue persist try flashing the BIOS. if issue still persist then have the motherboard checked out.
Mar 29, 2011 | Toshiba A205-S4577 Notebook
My car won't start when I turn the key. It will not even turn over. Could it be the starter?
Yes , or battery cable, not in park or neutral, bad prndl switch, fuseable link wire to starter solenoid bad?
Dec 27, 2010 | 1987 Oldsmobile Ciera
I cannot switch on my laptop. it was working fine last night, but in the morning, my laptop refused to get switched on. nothing happens even if I press the on button, no blinking of anything, no booting,...
You might try to remove and reseat the battery. Jiggle the plug for your charger just to make sure that it can deliver charge to your computer.
You may be needing a new battery for your laptop, especially if the laptop seemed to require more frequent charging.
Look for guidance on your manufacturer's web site about care and charging of your laptop's battery.
Sep 06, 2010 | Computers & Internet
My 3110 keeps on asking its security code then switch off
ur cache memory of file system which is present in c drive is full nd u mi8 b using many sims (frequent removal of battery causes d prob). so u hav to go to ur nearest nokia care center as u cant do nethng by urself nd i refer u nt to swtch off ur cell frequently. thnx
Oct 15, 2009 | Nokia 3110 Cellular Phone
I had the same problem my 5800 is not switching on
You might have on of these problems
1. Faulty charger
2. faulty battery
3. Reload the soft ware but very rare chances the phone behaves like this due to s/w issue
4. try & format the memory card
Sep 07, 2009 | Nokia 5800 XpressMusic Smartphone
Frequent interrruptions
Initially, I would suspect the battery (even when plug to the AC). To confirm, pls try running without the battery and purely on AC adapter. Alternately, it could be a loose component internally such as the memory, LAN or WiFi card and in some models, video card. In my Toshiba, it turned out that the WiFi was consuming too much power that it discharges the battery rapidly and the charger was having a hard time coping up. My solution was to turnoff the built-in WiFi and install a D-Link USB.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Computers & Internet
Switching off frequently
you want to put new software to your mobile! then the problem does not come!
Jul 01, 2008 | Nokia 3110 Cellular Phone
Nokia 2730 Cell Phone Logo
20 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
