Question about Linksys Wireless-G Broadband Router
Password protect my wifi
How do I password portect my Linksys wifi
  • 137 Answers
You have to use the webstyle interface to accress the settings on the router.. click start then cmd... in the new window type ipconfig..type the default gateway address in your internet explorer browser it will look like 198.162.1.254 once you do that you will be in the router and can set up wep encryption.. you will need to add that new key to every computer and device on your network.. wireless printer, laptops .. everything.. keep the number you create safe so you dont have to do it all over again if you cant find it someday.
Posted on Jan 19, 2009
How do I find my wifi password
if this is the first time setup, then you would consult the docs that came with it for the 'default' password.
If not, then you can log-in to the Router, (which requires yet another password...) and look at it, or at the least allow you to change it to something else.
Oct 11, 2014 | Linksys Computers & Internet
I would like to know my password
Most routers let you log in by putting their IP address into the address bar of the web browser. however this can be done wireless but probably in your case, you might have to hard line to the router. linksys and cisco use 192.168.1.1 and I think netgear and d-link use 192.168.0.1 and Belkin uses 192.168.2.1...some routers require you to use login id and password before they let you use the interface. with older cisco and linksys routers it is usually ID/password admin/admin or admin/password. newer routers have unique login Id's and passwords that are generally located on a sticker on the bottom or the back of a router. once you log in, you want to go to a setting such as wireless security where it states what kind of wifi protection you have...WEP...etc. and that is where your wifi password is located....or just manufacture reset the router and follow the steps as mentioned earlier.
Aug 28, 2013 | Computers & Internet
They keep saying i am keying in the wrong wireless password. Is this the router password or am i suppose to find another one. please help
My Linksys wireless router uses a different password to setup a wireless connection with the SSID (wireless account name) than the password for logging into the router for administrative purposes.
So I suspect you need a different password. However, without knowing which make/model of router you have, I can't help you identify where to find the information for your wireless setup.
Please add a comment with your router information for additional assistance.
I hope this helps.
Jan 02, 2012 | Linksys WRT Computers & Internet
I want to password protect my router
Welcome to Fixya. If you want to make you connection secure the you need to set a Network Key on your router and need to access the Wireless Settings Page.
To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security You can select either WEP, WPA or WPA2 to make it secure and under the Security Mode you will see there Network Key. The Network Key serves as a password or security code on your network to make it secure. Generate a personalize key for your network.
If this works dont forget to say thanks. Thanks for using Fixya.
Mar 03, 2011 | Linksys WRT120N Router
I purchased my wireless G 2.4 GHz broadband router a few years ago, and would like to allow my guests to use my protected network; however I don't know my key. How do I find out what my key is so I can...
Hello ,
Its better you can get into your wifi setting by 192.168.0.1 or 192.168.1.1 and check whether the key is visible in characters, coz in most of the wifi setting it used to be in this type * . So if it appears like that you can dissable your security settings for sometime. And when you get into your wifi setting it may ask for your password , the default one is USER ID: admin Password: password or admin
Oct 18, 2010 | Linksys Wireless-G Broadband Router
How do i lock my linksys router so no one can connect to my wifi.
To lock it, you need to password protect it.
On a computer connected to the linksys now.
Click the link below
192.168.1.1
On the page that comes up, it will ask for a username and password.
type in admin for the password, leave the username blank
You are inside the router..
Click on wireless, then right under it click on wireless security.
Where it says authentication, click it and change it to wpa2 psk
Where it says, PSK / Passphrase / Or Network key .. There is a text box to the right
In that text box is where You will have to type in a new password, and click apply / save settings.
Then.. The router will restart..
You have now set your wireless password.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
Aug 25, 2010 | Linksys Wireless-G WRT54G Router
Forgot password to WiFi How do I find out what it
To find the password/passphrase on the Linksys router, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router. On older models the username is left blank and the password is “admin”. On newer models, both the username and password is “admin”.
Once you get in to the router management tool, look for the security portion. There you will find the password or passphrase you are using for your WEP or WPA security encryption.
Dec 01, 2009 | Linksys WRT160N Wireless Router
How do I password protect my Linksis WiFi
STEPS to enable wireless security.
1. Please open Internet Explorer and type http://192.168.1.1
2. Leave it blank for username, type admin for password
3. When you have the setup page, click on Wireless tab, then click the sub tab Wireless Security.
4. Choose WPA-Personal for the Security Mode. Type in a password on the WPA Shared Key box (minimum 8 characters)
5. Click on Save Settings at the bottom. All set
Note: The password on WPA-Shared key is your wireless security password.
Jan 19, 2009 | Linksys Wireless-G Broadband Router
Device password????
Device ownership password:
Control Panel->add or remove programs-> Intel(R) PROSet/Wireless Software -> Modify -> Unmarked WI-FI PROTECTED SETUP
Dec 15, 2008 | Linksys WRT160N Wireless Router
Linksys Wireless-G Broadband Router Logo
87 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
