Question about Exercise & Fitness
Repco re 4000 treadmill insturction manual - Exercise & Fitness
4 Suggested Answers
SOURCE: Repco Sports Treadmill
Repco RP300TM wont start E1 error message
Posted on Jul 14, 2011
SOURCE: repco fitness Treadmill error E7
This happened to mine, e7 is an error in the incline, meaning that the incline is too high or too low in the accepted range for the starting position of the treadmill. When the treadmill starts it looks to see if the incline screw shaft of the incline motor is in the correct position. If it isn't it gives the error message and shuts down. This happened to us after we had moved and the treadmill was bumped around a bit, this caused the incline worm shaft to move out of position, and that is why we got the error message.
To fix the problem I just took the cover off the motor area of the treadmill (WITH THE POWER OFF AND CORD DISCONNECTED) and located the incline motor, it has a threaded rod and a big nut coming along side the motor itself. It is the smaller motor. On the end of the threaded shaft is a plus sign cut into the shaft, so that you can insert a philips head screw driver into it and rotate the shaft. The shaft will rotate easily in one direction. Insert the screw driver into the end of the shaft and rotate the shaft so it goes as far into the big nut holding it as you can, don't twist it tightly, just make sure that the shaft has gone all the way in without binding, it still needs to rotate freely in and out. Put the cover back on and then switch it on. The treadmill should now start right up.
Posted on Nov 24, 2011
Tip
Star Trac 4000 Treadmill Deck Bushing Replacement
Replacing a Deck Bushing or Deck Stop Delrin Rod on a Star Trac 4000 TreadmillTools Needed: Phillips Screwdriver, Pliers (optional). Tools needed may vary depending on your hardware.
  1. Switch the power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Loosen and remove the old deck bushings.
  4. Stubborn deck bushings can be removed with the assistance of pliers, once the screws have been loosened completely.
  5. Install the new deck bushings. (Check with mfr. for proper torque during install process.)
  6. Now, plug in and power on the unit.
Video of Replacing the Deck Bushing on Star Trac 4000 Treadmill
on Feb 11, 2015 | Star trac Exercise & Fitness
Tip
How to Change a Star Trac 4000 Treadmill Running Belt and Deck
This video will visually assist you in the procedure of changing the deck and belt on a Star Trac 4000 treadmill.
Star Trac Unisen Treadmill TR4000 Parts SPORTSMITH net
on May 15, 2014 | Startrac Fitness Products Exercise &...
Repco manuals
Do you mean
Repco Replacement Parts, Inc. and if so what manuals do you want
Nov 08, 2014 | Motorcycles
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
Need manual for RE1000 treadmill
please download from the website www.manualslib.com
God bless you
Dec 15, 2012 | Exercise & Fitness
Symbol LS 4000-I100 to a PC Help connecting
That depends on your exact model, it could be USB, Keyboard Wedge, or RS-232. In any case, you just plug it in and turn it on.
Oct 15, 2009 | Symbol PN: LS4000-I100 Laser Scanner...
Jul 15, 2009 | Exercise & Fitness
Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Jun 05, 2009 | Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
