Question about Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE doesn't heat
The vent is clean and the air flows freely
Generally when a dryer does not heat, there is some problem with the heater, either it has shorted because some metalic thing like a coin or pin ( or in our case the under wire of a bra) from the clothes managed to get to the back and short circuit the heating element or the fuse is blown, I am not sure u can take the dryer apart to be able to check with a meter , when it is the heating element. You need diagrams of the dryer to be able to know how to take it apart and to know which screws and parts come off first. Please disconnect the power before attempting any of this
Posted on Jan 20, 2009
  • jvaidy Jan 20, 2009
    I was assuming it is electric heater, if it uses gas, then the solution is in the same area, but I don't have a gas dryer and therefore have no solution.
Needs two cycles to dry clothes!
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 19, 2012 | Kenmore Dryers
Kenmore dryer model #110.62612101
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes;
May 17, 2012 | Kenmore 74112 Gas Dryer
Warm but not heating up kenmore 970C87192
excellent air flow and too extensive time to clean out lint trap and all other lint stuck in the machine behind the back panel. is there a way to look at the heating element and go yep its broken? haha like burned or snapped or could it appear perfectly fine and in fact be broken?
May 16, 2012 | Kenmore Dryers
The dryer simply doesn't dry my clothes
Are the clothes warm after cycle? If not heater coils may be bad. Is lint trap cleaned out? Have you checked the vent that exhausts the air to the outside? make sure it is cleaned and kink free and the air is flowing freely. If you can get to the end of the vent outside you could try running the unit and check to see if you're getting good air flow outside from the vent.
May 27, 2011 | Amana Dryers
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
My Kenmore HE5 dryer will not run without blowing an internal fuse. The repairman replaced the fuse, and it blew again. The dryer heats up but will not turn it's heating element off until the fuse blows....
Has any one checked the exhaust vent,other than a bad thermostat the number one cause for the thermal fuse to open is a clogged or restricted exhaust vent flow, the entire vent system needs to be checked ( not just the hose from the unit to the wall) for proper air flow. Turn the unit on TIMED ,AIR DRY (NO HEAT) and go outside to the exhaust vent and check the air flow,if there is any question as to weather the air flow is sufishent get someone out to clean the exhaust vent ,it always a good idea to clean out every few years regardless to help prevent build up of lint witch could cause a fire......Hope this Helps Good Luck
Dec 14, 2010 | Kenmore HE5 Electric Dryer
The dryer heats, but not enough and I have to dry my load several times on high heat. Help please
Hi, it sounds like a blocked vent. Outside, where the warm moist air exits the building, verify you have good air flow. If not, pull out the dryer and make sure there is no restriction, kinks in the vent hose, lint build-up, etc. If you have a vent restriction, it causes the heating element or burner to over heat and shut down prematurely which extends the dry time considerably.
Mar 17, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer takes over 3 hours to dry a load. It does heat and turn, but ?
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
Also make sure the exhaust vent is not over the recommended length (refer to the manual).
Let me know if you still need help.
Apr 01, 2009 | Kenmore Dryers
Kenmore elite HE 4 IS NOT DRYING AND GIVING BURING SMELL
ensure the lint screen is clean, check your discharge vent hose for blockage or kinks. You may need to move the dryer out from the wall to thoroughly inspect the vent hose. while the vent hose is removed from the dryer, start the dryer momentarily to ensure the is sufficient air flow exiting the unit.
Feb 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
