I have a maytag coin washer model mat10pdaal with error codes F5, 175 and 240 any idea what they mean?
  • 85 Answers
SOURCE: Maytag Nepture washer error code:
this is a code for too much soap is being used add vinager to wash tub to eliminate residual soap and run an empty cycle to rinse out. then use only 1 oz of HE type detergent only per load
Posted on Dec 14, 2008
SOURCE: What does error code Lr mean and how do I fix it?
http://www.bobvila.com/wwwboard/messages/155863.html
says:
just an FYI to anyone who might need to know. my neptune started kicking up an error of LR and stopping. i ended up sending an email to maytag and got a response back from one of their techs. the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
hope the info helps someone as i had a heck of a time finding it.
Posted on Jan 14, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
  • 1891 Answers
SOURCE: waht is maytag 9000 f-25 error code mean?
cant help you with that code its not on chart / but if you remove the three screwsin the bottom panel and removr it you can doo 2 things .. remove the cover to the pump and clean it out ( avery common problem ) and # 2 on the inner side pannel you will find the tec sheet with the codes . and you will be able to tell me what f 25 is . thanks hope i helped you ****
Posted on Dec 06, 2009
  • 1382 Answers
SOURCE: maytag epic z washer error code F21-have unplugged
F21 indicates a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump.
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesn't solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Thank you !!
Posted on Aug 01, 2010
Specs for model#MVWC400XW0 Maytag Centennial Washer
It definitely could be a clogged or bad pump. However, it's always a good idea to check for error codes before replacing a part...Especially expensive ones...
http://applianceassistant.com/Washer-Repair/Maytag-Centennial/Maytag-Centennial-Washer-Error-Fault-Codes.php
Hope it helps! Good luck!
Mar 02, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag coin operated washer and dryer. After the last service call the repair man ran off with the keys to the coin boxes. How do i get new keys to the coin boxes? Alternatively, how can i remove...
Unfortunately if you do not have a good locksmith, you will have to drill out the locks and replace them. Not a cheap solution by any means.....If I can help further, I am here.... Eric Campion
Feb 27, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Maytag commerical washer model MAT10PSAAW COIN MACHINE . THE COIN VALUE IS 1.00 IT SHOWS 2.45 THE FAULT CDE IS dA5 how to reset to working status
I have been answering other peoples problems on this site I am a electrician . I still haven't fix my freind washer yet because the Code reads dA5 If I new what this code ment I could fix rhe machine . The machine is a maytag model number MAT10PSAAW SER AO592928MF
THE MACHINE IS A COIN WASHER 1.00 COIN . IT SHOWS 2.45 if I could get it back to read 1.00 ,I think it would work . Again the code is dA5. I have been searching the net . knowone yet with a clue .
Nov 26, 2008 | Maytag Washing Machines
Commercial Energy Advantage High-Efficiency Front-Load Washer MAH22PRAWW
Take the front panel off, (12) screws in all. Start by the soap drawer (2 t-20's {safty type}). Then loosen the 4 T20's (also safty type) that hold on the aluminum face plate & display lens. Now the front meatl cover can come off (there is a snap clip by the soap drawer). Now remove the 6 - 1/4" inch screws 2- hold the top down, the other 4 hold the control board on. Now remove the control board & turn it over. You will see a white 3 pole connector plug, by it on the board it will say " service & coin". Remove the plug, now look at the display & you will see the error code. It will either be a "D" or an "F" code depending on your setup. Now push the lower left button on the panel (Delicates & Knits). your display should read 600 or 6 and a couple #'s (this is coin count). Replace the plug & your reset. Now just put it back together. Remember the display lens has a small window that need's to go bact into the upper left corner. I'll bet it will be an F22 or D17 - either way be carefull about closing the door (make sure nothing is caught by the door and boot seal). D8 or F21 -means long drain watch how much soap you use 1/4 cup or less is best. I hope this helps you.
P.S. keep track of the error codes- Maytag/Whirlpool may owe you an upgrade on the machines software.
Sep 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Error code PF
THIS is a "Power Failure " Clease the code (press Cancel button) and see if it starts up
Jan 23, 2008 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
