Question about Dryers
Maytag dryer smells bad
Rotten dead animal smell from dryer. Have taken out filter and bottom container, cleaned all and inside fluff Any ideas Regards Tracey Australia
  • 139 Answers
SOURCE: dryer burning smell
Is the fan running....with strong airflow out of the vent pipe? Is the smell coming from the vent pipe? If the vent pipe goes outdoors...is the smell coming from the control panel at the top??
ODOR FROM VENT:
If the fan is not running, or the air is somehow blocked, then the odor is probably caused by excessive heat around the heating element. A seriously overheating element should eventually cause a thermal overload protector to "trip" and shut off the power.
If the airflow is strong, the air intake may have drawn in paper, dust, lint, or something that is near or stuck on the heating element.
ODOR FROM CONTROL PANEL:
A relay, temperature control, timer module, or other part may be burning out. The defective part could possibly be found by "sniffing" the parts in the control panel to find the source of the smell...with the power unplugged!!...otherwise, this may require testing by someone familiar with appliance repairs.
Posted on Jan 22, 2008
  • 66 Answers
SOURCE: Bad smell inside dryer
you might want to vacum the lint filter and the all the fan blower area some thing in the dryer is dead .
Posted on May 10, 2008
  • 958 Answers
SOURCE: Duet Dryer
burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
i hope i was able to solve you problem..
pls rate me.
tnx
drcool
Posted on Jul 22, 2008
  • 10 Answers
SOURCE: black soot in dryer
There are several possible causes: a)  exhaust vent is restricted forcing the lint to enter the dryer shell and overheat and/or be picked up by the blower -- you seem to have inspected this b)  check the hot gas inlet to the drum.. on some dryers, lint buildup can occur in tight spots and it will overheat and char c)  ducting is not intact or leaks allowing lint to leak into the dryer shell -- this will occur over time, and all dryers should be taken apart and cleaned out on a regular basis... also, all ducting should be inspected and sealed as needed d)  verify that the inlet vents to the dryer shell are not blocked and allow adequate air flow to the burner assembly -- natural gas normally won't smoke due to incomplete combustion, but..  likewise, verify the room has adequate ventilation particularly if the utility room or closet is very small,  e)  check the drum drive belt, as it gets old, it will release dust and minute pieces which will be picked up by the blower -- replace if needed... f)  verify that the seals on the drum are still good -- replace as needed g)  as 'washer-tech' advised, do a thorough cleaning and inspection... put it back together with all ducting tight and free flowing
Posted on Jul 27, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer smell of gas inside and venting
hi thanks for the question you don't have a problem if you smell the air going out of the house it will have that smell thanks the appliance doc
Posted on Sep 18, 2008
The washer for our Maytag LS7806 has quit, but the dryer still works. A few weeks after we stopped using the washer, it started to smell of rotten eggs. I can't find a filter to clean, any ideas?
The bacteria in the washer part are causing the smell.
Give the inside a good wipe round with a damp cloth to remove any visible residue.
Leave the door and soap drawer fully open so that the inside dries out after a couple of days; that should fix it.
Jan 06, 2018 | Maytag Washing Machines
Kenmore dryer 11069622800
It might be a dead animal in the dryer duct that vents the hot air outside. Sparrows are notorious for building nest in dryer and air ducts that are elevated several feet off the ground. Don't know how the smart little birds figured it out, but they are able to lift the outside flap and get inside. If your outside vent is located several feet up I would check for a nest. If it is close to the ground, then it might be a 4 legged critter that crawled inside and died. It is impossible to see into the vent, so take a cell phone with a camera and flash, or a small digital camera and slide it under the flap / damper to take a few pictures of the inside of the duct. If you do happen to have something in the duct, and it runs for some distance inside the wall, then it might take a company like Servpro to come out and clean the duct out.
Apr 26, 2014 | Kenmore Dryers
Odor
if you have a bad odor,pull off the vent line from the back and see if an animal is dead there,i've found dead birds,mice and a possum,in the blower wheel of some dryers,they get in from the outside hood,once they get into the vent line and slide down they can't climb back out or if the dryer is running the wheel does a job on them.also if you had some painting or staining done this also can make the dryer smell bad.this is going by what i've found when someone complains about an odor in the dryer.hope this helps,one more thing if the motor is overheating from the dryer not being cleaned out it could have like a shellac smell,you might have to take the dryer apart to see what's stinking or it could be something near the dryer,when the air is heated in the dryer it makes the smell worse but if you find waht is causing it and remove it the smell will go away,if it is from a dead animal you can wash down the area with soapy water,you don't want to use anything with a strong smell because your clothes will smell of that when the dryer heats up.what does it smell like?
Apr 13, 2013 | Maytag Atlantis MDE6400AY Electric Dryer
Hello. When our Rinnai direct vent wall heater lights on it smells of gas. I do not recall smelling this before. It is a sweet smell not a sulfur smell. The filter is clean.
If it's a sweet smell. it's not gas. Gas smells like rotten eggs. There may be something inside the heater that's causing this odor. Remove the cover of the heater and look for some foreign that shouldn't be there. Perhaps, a dead mouse.
Feb 16, 2011 | Rinnai Heating & Cooling
My LG dryer is about a year old and suddenly smells musty and mildewy inside! The washer is just fine (that seems to be the majority of complaints) but the DRYER definately smells. I clean the lint tray...
yes I have the same problem and can't find help anywhere...it smells like mold but my husband says like a dead animal and it gets smellier by the day. I leave the door open on both the washer
Jan 02, 2010 | LG Dryers
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Weird smell from refrigerator
Is the smell from inside the refrigerator or on the outside? If outside, it is possible a humid smell from the condensate drainpan water evaporating. You could put a very small amount (a couple of granules) of pool chlorine in the drainpan.
Mar 03, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
MAYTAG FRIG SMELLS LIKE A DEAD ANIMAL!!
use bleach straight bleach to clean it it will usually kill any odors coming from a refrigerator clean it both inside and out
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
May 10, 2008 | Dryers
Dryers Logo
Top Dryers Experts
