Question about Sony PlayStation 2 (PS2) Console
No video and audio output - Sony PlayStation 2 (PS2) Console
  • edie Jan 02, 2013
    how to fix ps2 when no video and audio output?the av cable is comfirm in good condition
    Problem Solver:
  • 5 Answers
The back 3 wires i.e. red white and yellow are not connected properly behind yr television !
Posted on Jan 28, 2013
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Linkā„¢ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    Panasonic DMR-HS2. Why doesn't DVD tray open or close and why is there no audio/video output?
    Tray movement failure can result from a weakness in electrical or mechanical components.
    "hooked up both RCA audio/video outputs to my HDTV". Often the RCA outputs are coded R (right audio), W (left audio), and Y (video). If these are not connected to corresponding inputs on the rear of the TV, you will not hear/see much.
    Do I need to use a(n) RF modulator to connect to my HDTV to see video? No
    Mar 04, 2016 | Televison & Video
    We have no sound when we play a disc..picture is on.
    How are the DVD player and the TV connected?
    Coax cable? (Carries both audio & video.)
    Composite output? (Red & white for audio, yellow for video)
    Component output? (Red & Blue & Green for video, White & Red for stereo audio)
    DVI output? (Video only)
    HDMI output? (Carries both video & audio)
    Feb 14, 2015 | Televison & Video
    I got a new tv and dvd player and all the wires were pulled out and now i do not know how to reconnect it...
    Basically all analog audio inputs and outputs are complementary of each other, such as audio output mates with audio input or viceversa. Video output mates with video input. You typically should have a composite video connector on your both DVD and TV set. Reconnect them directly. As you can imagine, DVD audio and video outputs should go to audio and video inputs of your TV receiver. Good luck.
    Mar 15, 2014 | Pioneer VSX-455 Receiver
    How to convert a videos
    Launch your video converter program if you have one.
    If you do not have a video converter program, consider free programs such as AVC Video Converter http://download.cnet.com/any-video-converter/3000-2194_4-10661456.html
    or
    Prism Video Converter
    http://dw.com.com/redir?edId=3&siteId=4&oId=1770-20_4-0&ontId=2194_4&lop=linktitle&ltype=dl_elite_gen&pid=12172333&mfgId=10012381&merId=10012381&ttag=lst-1&destUrl=http%3A%2F%2Fdownload.cnet.com%2FPrism-Video-File-Converter-Plus%2F3000-2194_4-1064
    These programs are cross-platform applications, compatible with both Windows and Mac OS X operating systems.
    Click "Add Files" or "Add Video," depending on the program that you are using.
    Locate the video file you want to convert from the folder you saved it in, then click "Open" to import it to the video converter program.
    Play your video on the monitor to ensure that it is the video that you want to convert.
    Select the video format you want to convert your video to in the "Output format" or "Profile" window.
    Choose from a number of video formats, such as MP4, AVI, MOV or WMV. Different models of MP3 players use different video formats, so refer to your MP3 player's documentation for the compatible format.
    Select the output video size you want to use. Video sizes vary with different MP3 players. Some MP3 players support 320x240, while others support 640x480.
    Refer to your MP3 player's documentation for the supported video size.
    Select the audio codec that you want to use for your output video file.
    Some of the most common audio formats include MP3, WMA, AAC and WAV.
    Audio codecs compress audio with different output quality settings, so refer to your MP3 player's documentation for the supported audio codec.
    Select 2 or "Stereo" in the channels box for a balanced left and right audio output.
    Click "Browse" and select the folder where you want to save the output video.
    Select a folder or location that you will be able to remember and access quickly.
    Click "Convert/Encode" to begin the video conversion process.
    A status bar displays the progress of the conversion.
    When the process is finished, your video is in the format that you selected
    hope this helps
    Sep 27, 2012 | Audio Players & Recorders
    My iPhone plays videos on the Internet but no sound comes out, why Is that???
    If your having problems with no audio from youtube, myspace and flash video. I suggest this
    When watching web pages with embedded Flash video or animation such as movie or video clip on YouTube and MySpace using Mac OS X, users may hear no sound. The no sound audio output problem happens despite video playback is fine, and the issue can happen on any web browser, i.e. Safari and Mozilla Firefox. Strange thing is that, when using other applications such as RealPlayer, QuickTime Player and VLC Player, the sound is played properly. And no audio output issue does not affect embedded QuickTime including HD contents on the web.
    Apple Mac OS X support site explains that the no audio from certain multimedia content issue is caused by some audio applications that change the computer's audio settings to a sample rate that is too high for other applications to use. The notorious programs include certain versions of Real Player, VLC Player and Audacity.
    The solution to solve the Internet movie no sound or audio output is to reset the audio setting in Mac OS X to original configuration:
    1. Open "Audio MIDI Setup" (/Applications/Utilities/), then check the "Audio Output" setting.
    2. Change the "Audio Output" setting to 44100.0 Hz.
    3. Quit Audio MIDI Setup.
    If the Audio Output setting is grayed out or disabled, go to "Properties For" tab in Audio MIDI Setup, and select "Built in Output".
    I hope this helps
    Dec 14, 2010 | Apple iPhone 3G
    Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
    from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
    Nov 13, 2010 | Hyundai Televison & Video
    How do I know which converter box to buy?
    here are the specs for the Magnavox TB100MW9
    Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
    Jan 04, 2009 | Televison & Video
    I want to duplicate a vhs tape....how do i hook up 2 vcr's and the tv to do so?
    vcr1 plays the tape
    vcr2 does the recording
    connect vcr1 video/audio output to vcr2 audio/video input to audio/video output to tv audio/video input
    May 27, 2008 | Televison & Video
    Video Connections
    These are all the connectors on the back. The "1 x component video output" indicates that you can use the "3 color video cord" you have, better known as Component Video Cable.
    Connector Type: 1 x HDMI ( 19 pin HDMI Type A ) - rear ¦ 1 x component video output ( RCA phono x 3 ) - rear ¦ 1 x S-Video output ( 4 pin mini-DIN ) - rear ¦ 1 x composite video output ( RCA phono ) - rear ¦ 1 x audio line-out ( RCA phono x 2 ) - rear ¦ 1 x 5.1 channel audio line-out ( RCA phono x 6 ) - rear ¦ 1 x digital audio output (coaxial) ( RCA phono ) - rear ¦ 1 x digital audio output (optical) ( TOSLINK ) - rear ¦ 1 x network ( RJ-45 ) - rear ¦ 2 x USB - front
    May 16, 2008 | Toshiba HD-D1 DVD Player
    Sony PlayStation 2 (PS2) Console Logo
    15 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
