Question about Sharp LC 60LE830M 60 Multisystem 3D LED TV
What is cause of purple spot on lcd screen - Sharp LC 60LE830M 60 Multisystem 3D LED TV
    New Friend:
Defective panels sold by sharp - MANY with the 857U model have the same problem so it is a defect and not your fault. Sharp will want you to give them cash to swap it out for second hand previously used unit.
Posted on Feb 22, 2015
55 inch Samsung smart tv. Has two purple spots showing on the screen. One on left side and other on right bottom.
If you wish to get more details visit the site linked here. Faults and possible causes of both LCD and plasma TV screens are given with illustrations. http://electronicshelponline.blogspot.com/
Feb 22, 2017 | Samsung Televison & Video
White purple spots
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Sharp LC-60LE835U AQUOS 60 In. 1080p LED...
Purple spot on kdf-e60a20. Screen
its possible something in this DLP is on the lens that projects the picture onto the screen or the mirror (do not touch it) or between the lens and the inside of the screen---anything will if there show up in the picture.
In some cases I have used compressed air to dust these out but carefully.
Nov 04, 2012 | Sony KDF-E60A20 60 in. LCD HDTV
I have a CP-X300. The bulb has 1200 hrs on it. It has gotten a redish purple spot in the center of the screen. Do I need a new lamp or something more? Thanks
You have heat damage on one or more of the LCD units. They are not repairable and must be replaced to fix your fault. The cause is excessive heat possibly due to a blocked air filter or fan.
Feb 12, 2011 | Hitachi CP-X300 LCD Projector
My Samsung LCD TV takes 1 minute to turn on with purple spots
could be the power supply board (most likely) or the main board.
Nov 17, 2009 | Televison & Video
How do i fix or get rid of a green spot and a couple of purple spots on the tv screen?
Does your model end with a "5" as in PTnnLCX65? If so call the Panasonic call center to schedule service or find a servicer, they have a fix for colored spots on the 2005 MMDs ending with the number 5. The fix is being coverd under warranty.
Sep 14, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Light purple spots on my screen
Unfortunately, this sounds like a problem with your TV's lamp. They are not cheap to fix. Search Ebay for a new lamp and get someone to install it for you. These Mitsubishis have a design flaw that make the lamps burn out quickly.
One thing that will PREVENT this problem is making sure that the TV's vents are clean.
Dec 29, 2008 | Mitsubishi WD-62528 62 in. LCD Television
Random purple spots on screen
I have the same issue with the WD-52528. I was told it may be a bad light engine. Service is coming out August 27th. I'll let you know what they say.
Aug 21, 2008 | Mitsubishi WD52527 52" Projection HDTV
Purple and Blue Spots on Screen on Mitsubishi WD52527 52 Inch HDTV
It could be only dust building up and it needs a good cleaning or it could be the DMD board is going bad and needs to be replaced.
Mar 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Its not a camera its a electronic dictionary
The cracked LCD itself can not be fixed, however a replacement LCD is always an option.
They are fairly cheap, running around 40-50 dollars.
Here is a link to one on eBay -
http://cgi.ebay.com/Sony-DSC-P100-P120-P150-Digital-Camera-Parts-LCD-SCREEN_W0QQitemZ250125094940QQihZ015QQcategoryZ64352QQcmdZViewItem
Hope that helps!
Nov 17, 2007 | Sony Cyber-Shot DSC-P150 Digital Camera
Sharp LC 60LE830M 60 Multisystem 3D LED TV Logo
977 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
