Question about Kodak ESP 5 Printer
Printer head missing or not installed properly.
I took out inks, took out case, shut door; waiting. opened door, installed case, installed inks. Same error msg -
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
First change the old head with the new box pack head if the problem persist then change carriage unit the problem will be clear.
Posted on Jan 02, 2013
etuckram
  • 34 Answers
SOURCE: New Printer will not go past "Please wait..."
what you need to do is to remove the inks and the printhead again and then install it. You just put the printhead improperly. Then once you have cleared the error connect it to your computer and upgrade the firmware by going to www.kodak.com/go/downloads
Posted on Jun 09, 2008
SOURCE: need to replace ink cartridges and the printhead
I have a kodak esp 5200 and just replaced the color cartridge. All you have to do is go to your little panel and go to maintenance. Scroll down to change ink cartridges and it will tell you to open the cover and replace the cartridge. I didn't know how either and just tried a few things. Hope this helps.
Posted on Apr 17, 2010
  • 13433 Answers
SOURCE: My Kodak ESP 5, all
Hello, and thanks for using FixYa.
If the error remains after you had removed cartridges, removed the printer head, cleaned its contacts and reconnected it. then the printer head would need to be replaced most likely. If the problem remains with a new printer head the printer is faulty and you can not fix it yourself. If you are in warranty get in touch with kodak to get the machine repaired.
The new printer head costs around 40 to 80 $
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Posted on Oct 14, 2010
  • 739 Answers
SOURCE: how do I remove the
Is it still switched on?
Posted on Feb 09, 2011
  • 352 Answers
SOURCE: error on my printer says
Remove the cartridges and Print head if possible, unplug the printer for 10 mins, switch on and Re-install the head and cartridges.
Hope this helps GM
Posted on Apr 08, 2011
Even after reinstalling printhead an ink cartridges on Kodakhero 5.1 printer, I still get the error message that the printhead is loose, missing, or not properly installed. What do I do?
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in isopropyl alcohol or hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work, then you need to try soaking the print head. In this case:
(1) Remove the print head from the printer
(2) Soak it in hot water for an hour or so
(3) Remove it, let it dry completely
(4) Replace the print head and cartridges and test it
Apr 05, 2013 | Office Equipment & Supplies
Get msg printer head missing or not installed properly.
First change old head with the new box pack head if the problem presist then it is the problem with carriage unit.
Jan 02, 2013 | Kodak ESP 5 Printer
I don't know how to load the ink into the printer of the iP 1600 Canon pixma
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Apr 25, 2011 | Office Equipment & Supplies
I have just put new ink cartridges into my Kodak ESP 3 printer and I have recieved the message that the printhead is missing or not installed properly. I have taken out the printhead and put it back in but...
Hi
Try to clean the print head manually until ink flows. Rub the print head into a plain paper with rubbing alcohol until in flows. Then try to print again.
Clean also the contact point of the ink cartridge by a cotton swab to clean some dirty on it and try to plug back ink cartridge again.
Try this solution also,
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
If still not working, maybe the ink cartridge is defective. If under warranty, return it for free replacement.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Apr 25, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error 5200
This error indicates that the Waste Ink tank is full. In some cases, resetting the counter will fix clear the error, but in some cases, it couldn't be fixed until you clear or clean the ink pads inside the waste ink tanks.
First try this:
  1. With the printer turned on, unplug it.
  2. Open the top and bring the ink cartridge holder to the middle.
  3. Raise the gray bar and remove the print head assembly with the cartridges in it.
  4. Lower the gray bar with the head missing and close the top with the head out.
  5. Restore the power,wait till The printer wakes up.
  6. It will tell you to install the cartridges, do so.
  7. Restore the print head, close the top and the printer should resume working.
If the above trick didn't help, watch this video and follow the instructions [the model is different, but the method is more or similar, you'll only need to know how to dismantle the machine]:
You can also follow this "How to" [Click Here].
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jan 31, 2011 | Canon MP490 InkJet Printer
My large black ink cartridge with not print correctly on my Canon Pixma MP830. All the other colors work fine. I've done numerous cleaning and deep cleaning. Then replaced the cartridge and it still prints...
Are your black ink cartridges genuine Canon ones?
Are the contacts clean when you remove the cartridge?
If not blow off with compressed air and a clean brush, if necessary.
Canon.com's site covers the verification that the cartridges are installed correctly below:
Issue: Black ink does not print
Solution: Confirm that the recommended ink tanks are installed properly MP800R / MP830
Replacing an ink tank When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. Recommended Ink Tanks:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note:
    When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Check the ink tank. If the orange tape is as shown in Figure <1>, it is properly removed. If the tape is not removed (as in figure <2>, pleease remove the extra tape).
  6. Insert the ink tanks into the print head.
    Note:
    Press the mark "PUSH" on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  8. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Jul 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Will not print . machine tries to engage cartridges no succes checked that cartridges are installed correctly. model D2360.
Remove the ink, turn off the printer, turn on the printer after several seconds, wait for the printer to cycle and give you a "no ink" error light. Open the lid of the printer. Wait for the print head to position itself, then install your ink and close the lid.
Many people ram the ink in before the printer does that last cycle; it can lock the printer, cause an error, or in a worst case scenario it can strip the gears on the head permanently damaging the printer.
Dec 11, 2009 | HP Deskjet D2360 InkJet Printer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Installation of the cartridge for Canon Pixma iP1600 printer
To print normally, install or remove ink cartridges in an orderly procedure.
cartthingsnottotouch.jpg3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
ip1600puttinginink.gif4. Confirm that the ink cartridges are installed properly.
Jan 06, 2009 | Canon PIXMA iP1600 Printer
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Kodak ESP 5 Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
