Question about Maytag MER5770 Electric Kitchen Range
F1 alarm and oven won't turn off - Maytag MER5770 Electric Kitchen Range
Turned off circuit breaker and serviceman coming. A piece of toast caught small fire inside oven, and I suspect the temp. rose too high and now oven won't turn off either when plugged on. Thanks anyway.
Posted on Jan 19, 2009
2 Suggested Answers
mgprice
  • 744 Answers
SOURCE: GE oven functional code F1 appears.
Hello, I come across this problem quite often, The f1 error code does not always follow that it is a bad EOC (Electronic oven control) This could also be a problem with the touchpad. The way to figure which is bad is turn electric off, access the EOC and pull the wire harness/ribbon tape for the touch pad. Reassemble the range and switch power back on. If you are still getting the F1 it is the EOC..If the F1 clears then your problem is with the Touchpad. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Posted on Aug 18, 2009
The F1 error code is lite and alarm noise won't shut off. turned off breakers and the alarm stopped upon turning back on but F1 lite is lite.
With your model & Serial number you should be till able to order the EOC (Electronic oven control). But they are not cheap.
Mar 17, 2015 | Ovens
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
Cannot turn off the alarm - show F1. I turned the power off for 2 days - no help. When you hit clear off - it stops for 10 or 20 seconds then back on.
F1 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 11, 2010 | GE JTP45 Electric Double Oven
I have a maytag oven with f1 and f3 codes what
F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
Nov 09, 2009 | Kitchen Ranges
Aug 18, 2009 | GE Kitchen Ranges
F1 and alarm going off .turned power off and and on .kept flashing f1 and alarm noise
normally the f1 code stands for failed matrix in the control brd behind the panel. by removing the panel, after disconnecting power you should find a tech manual which should show the code and solution
May 19, 2009 | Ovens
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
Oven wont work
when i turn onether oven then a bipping alarm and oven will not come on. light come on but not heated up.
Aug 30, 2008 | Ovens
Maytag MER5770 Electric Kitchen Range Logo
145 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
