Phoenix BIOS ID: NAPA0001.86C.0059.D.0704131512 update
Update downloads
leecom72
  • 4806 Answers
SOURCE: bios update for VIAP4M
Hi there
Go to this support website, select your model motherboard and download the drivers you need:
http://support.octek.com.au/products/mainboards/P4/Intel/mb_p4_i_74.htm
Good luck and thanks for using Fixya
Posted on Feb 18, 2009
preachw996
  • 1179 Answers
SOURCE: BIOS update for Asus A7V-ML
For branded computers like HP, Compaq, Dell the only place you can get the correct bios updates would be your computer manufacturer website under the support link. These companies do not use industry standard motherboards so it could corrupt your system to update from any other source. Hope this helps.
Posted on Apr 27, 2009
cowboytech
  • 69 Answers
SOURCE: Blue screen on start-up. Mobo SIS-741 Chipset SIS741GX Rev 03
This problem can be caused by several things. First, are the memory chips exactly identical (brand, type, size, etc.)? If not, that will definitely cause the problem. Second, how many memory slots are there? If you have four, check the manual and make sure you're putting the memory in the correct slots. Some Mobo's require that you put chips in slots A1 and B1 and not A1 and A2. Also, some Mobo's have DDR slots and DDR2 slots, so make sure you're putting the right kind of memory into the proper slots. Some people fudge the memory by putting 400 mhz memory into slower slots, and that works one chip at a time - but if you install a second, identical chip, the system will fail. If all else fails and you've met these conditions, check the type of memory to be sure of the proper fit (use manufacturer's recommended brands and numbers) or try a different chip in the second slot. One chip could be bad.
Posted on May 25, 2009
AndrexT
  • 20407 Answers
SOURCE: bios update
If updates are available, you can always get them from the motherboard manufacturer's website.
Why do you think you need an update? If something goes wrong like a power cut, or computer problem, your motherboard will be scrap. Doing bios updates is very risky and should only be undertaken if absolutely neccessary.
Regards
sir andrew
Posted on Nov 25, 2009
Update phoenix bios
1 download bios file
2 remove bios ic
3 inserting bios copier to bios
4 coppy bios file and paste to bios ic
Aug 30, 2013 | Acer Computers & Internet
Phoenix d686 driver
Phoenix creates computer BIOS programs, not drivers. BIOS updates can usually be downloaded from the computer manufacturer's website.
Mar 03, 2011 | Computers & Internet
Upgrade phoenix bios 4.0
Go to the website of the company who makes your laptop or desktop. The majority of these sites have a portion of their site they devote to updates. Look in this section to locate your BIOS updates. When you find the file you need, download the BIOS to your computer's hard drive.
Go to Biosman to download and install the Phoenix BIOS flash utility software. This software allows you to read the data your BIOS file contains.
Flash your BIOS via USB storage device. Copy your update to the USB drive. Then, modify the boot order of your laptop or desktop to begin with your USB drive. Push "F2" or whichever key prompts you to enter your BIOS when you reboot your system.
Double-click the BIOS file you just downloaded to run the upgrade procedure.
Good Luck
Jan 08, 2011 | Computers & Internet
In need of a pci/pnp 586 manual. anyone got?
BIOS INFORMATION :
BIOS MANUFACTURER : PHOENIX BIOS V.4.05 R 1.0 - (C) 1985/1995
BIOS ID : UNKNOWN
BIOS DATE : 11/23/95
BIOS ROM SIZE : UNKNOWN
CHIPSET : ALi M1511 REV.4
SUPER I/O CHIP : SMC 665GT REV.2 FOUND AT PORT 3FOH
CASE LABEL :
COMPUDYNE - PENTIUM PROCESSOR
P/N: 91.AA884.003
S/N: 1900001233
INSIDE THE CASE :
3 ISA SLOTS
3 PCI SLOTS
4 EDO MEMORY SLOTS
1 ALi CHISET - M1513 A1 - 9542 TS2 - AC7129SB
1 ALi CHISET - M1511 A1 - 9538 TS5 - B40958SB
2 ALi CHISET - M1512 A1 - 9537 TS2 - B40954SA
SOUND ONBOARD - CRYSTAL - CS4232 KQ EP - 33 PIN CN11 WAVE TABLE - 07 PIN CN12 AUDIO MIDI
PHOENIX MULTIKEY - PHOENIX 1987-1993 ER129
PHOENIX MB - 586 PCI PNP - PHOENIX TECNOLOGIES - A448416
INTEL PENTIUM PROCESSOR 133
NUMBERS IN WHITE INK ON THE BOARD TOP SURFACE :
95115-1
V50S MB
and
48.57001.011
MADE IN TAIWAN R.O.C.
Aug 29, 2009 | Intel Motherboard
Bios
just download a bios update of the web page of the fabricant, all fabricants have diferents modes to upgrate, somes need a floppy disk, others can be upgrade from windows running
Jul 20, 2009 | Dell Dimension 8300 PC Desktop
I want to update motherboard bios. manufacturer : esys current bios : Phoenix-Award bios oem : 945p Release 10/24/2005 V6.00PG
DISCLAIMER: It is NOT recommended that you upgrade your BIOS firmware unless you are a.) experiencing a problem related to your BIOS; or b.) a qualified service technician. Updating BIOS firmware can give you undesired results, not the least of which is the complete malfunction of the computer.
TO WIT:
Phoenix WinPhlash is a Windows-based application for re-programming Flash memory device that contains a PhoenixBIOS with Flash2000™. The utility works with all Windows operating systems and works in: Advanced and User modes. Advanced Mode is for engineers and provides full access to the DMI strings and all WinPhlash options. User Mode is for PC users who need to save or update their platformware safely without corrupting the code or causing system failures. Phlash16 comes with WinPhlash as well as documentation for support technicians, end users, and developers of platformware.
AND:
The next post will have a download link...
May 17, 2009 | Computers & Internet
Computers & Internet Logo
232 people viewed this question
David Payne
David Payne
