Question about La Pavoni EUROPICCOLA EG-8 Espresso Machine
On my 6 momnths old europiccola no water coming into group
Was working fine until few days ago; used alkaline water; decalcified but still the same. After long wait (3-5 mins) some water comes to group and can make coffee. Not possible to "purge" the head as no water coming out. Steam coming out OK.
  • dreammaker12
    dreammaker12 Feb 05, 2013
    Disassemble the head (remove circlips and bolts and push it all deep in until everything comes out - remember the order of things coming out) and screw the piston on the pushrod few turns more (or fully if you want) and re-assemble. It worked for me great! Good luck.
Hi, I have the same problem, i bought mine this summer so we have had bad luck , we call it mondaysamples here in sweden, im still investigating how to solv it, keep me updated if you are lucky, i will send you info if mine will be fixed /Peter
Posted on Feb 04, 2013
mirran
  • 515 Answers
SOURCE: Steam not frothing properly (very weak output)
It can be the electric magnet valve that has to be replaced.
Posted on Aug 03, 2008
z34aga
  • 137 Answers
SOURCE: adding pressure gauge to Pavoni Europiccola
  1. in the boiler water is heated and presured up to 1.5 bar
  2. when water gets in lever and non return valve closes becouse you press the lever down, your energy is used to get high pressure, it should be frpm 7 up to 9 bar.
  3. SOLUTION==if you search way for modifying, you must consider that you must pump directly to group, not to boiler. in this case water will be cold (becouse comes from pump). you will need boiler in boiler to heat the water wich comes from pump before it gets to group. this is bit more complicated than you thought may bee but it is only solution.
Posted on Mar 30, 2009
LaPavoniBoy
  • 36 Answers
SOURCE: water leaking from the group
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Posted on May 28, 2009
espressonist
  • 1711 Answers
SOURCE: System is not priming
This is normal after you leave the machine unused for a long time. The water dirt or scale or both make many parts to stuck like glue. The presure pump might be stuck if even if you here the noise of the vibration the outlet have been blocked. another part that can be stuck for the same reason is the water solenoid. Both can be fixed by remove them desasemble them and clean them with a wire brush. If you have a litle technician knowladge this is a very simple operation. Of course if you persist you might unsuck by trying the procedure you mention but it seems that now it is hard to be hapen.
Good Luck
Remember to vote for this answer.
Posted on Feb 28, 2010
  • 100 Answers
SOURCE: my la pavoni europiccola will not pull water
Machine needs to be rebuilt with new gaskets. We do this repair
www.dolcevitaespresso.com
Posted on Feb 15, 2011
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Water presure or clogged up.
I don't have the same brand, but I had a similar problem. These machines depend on generating high pressure (bar) and clogging is a problem. One source of clog is calcium and minerals in the water. Even though you have and change the water filter, there will still be minerals in the water and it can result in clogging.
You should use a decalcifier periodically but for the problem you are having now, you most likely need to take the head apart and clean the mesh and parts. Make sure light comes through all the holes. Don't enlarge the holes. Just clear them. That is what did it for my unit. Hope that helps.
Mar 24, 2014 | Breville Barista Express
Whirlpool refridgerator ice machine mod.ED2PHE water will not come into ice machine. it was working fine until 2 days ago.
check water line is open, check filter seated properly,make sure of on/off lever or switch or turn off water supply to fridge and check line for possible clog, and also on filter
Jan 24, 2013 | Whirlpool Refrigerators
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
I only get foam after 4 Shots
The only thing that comes to mind is descaling. To me it seems that most of the boiler room is being lost to minerals, so there is less water in there. Try descaling the machine.
May 31, 2009 | La Pavoni Europiccola EPC-8 Espresso...
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Adding pressure gauge to Pavoni Europiccola
Feb 20, 2009 | La Pavoni Europiccola EPC-8 Espresso...
I can't get any water out of my machine
rod into piston may be slack stopping water coming into group at inlet hole - take piston out and tighten rod. I had this same problem and this fixed it for me. Slackening occurs through time - maybe too much coffee in basket and forced onto base of group.
Mar 28, 2007 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni EUROPICCOLA EG-8 Espresso Machine Logo
117 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
