Question about HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB 10/100 GL/2 HD- W/ LEGS C7780BABA HPHEWLETTPACKARD Printer
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
    Problem Solver:
  • 10 Answers
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Posted on Jan 02, 2013
  • 141 Answers
SOURCE: error on display
either bad carriage or trailing cable if you've already tried new inks.
Posted on Sep 05, 2008
SOURCE: HP designjet 1050 C plotter system error 04c3000 25c0000
when installing a network card i am getting this error cod 04c00 00002a0a
Posted on Sep 10, 2008
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
  • 99 Answers
SOURCE: hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Posted on Aug 01, 2009
  • 123 Answers
SOURCE: i have the probleum in Hp designjet 500 plotter
The problem is a defective Service Station. It will need to be replaced. The part is available at: http://www.lpscomputer.com/p-2493-c7769-60149-designjet-500-800-service-station.aspx
Posted on Apr 15, 2010
How do i fix error code 2.0.10 for designjet t790 plotter?
Problem with the Carriage PCA
Corrective action: Try the following:
1. Switch the power off from the back of the product and disconnect the power cord.
Reconnect the power cord and power on the product.
2. Check that the Trailing Cable is not damaged. Check that the Trailing Cable is correctly
connected between the Engine PCA and Carriage PCA.
3. Replace the Carriage PCA. See Carriage PCA on page 334.
4. Replace the Trailing Cable and Carriage PCA Covers.
5. Replace the Engine PCA. See EE Box on page 370.
Dec 01, 2014 | Office Equipment & Supplies
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
Can anyone tell me what is System eror 010033 00070B1F ?
That indicates the trailing cable has shorted out the main board. Sometimes replacing the trailing cable will fix the problem, but I don't think they are available anymore.
(The Trailing cable is white flex cable that goes from the carriage to the main board on the back of the plotter)
If you find a new one and don't get it installed perfectly square and aligned with the pins right, it will short out the main board, so I recommend getting it replaced by a trained HP technician or a tech familiar with testing the cable for a short before turning the plotter on.
Aug 23, 2013 | HP DesignJet 755cm InkJet Printer
Error code 02.1.10
02.1:10 service station error- failure to reach home position .
you need a service tech to replace the service station within the plotter
Aug 14, 2013 | HP Designjet T1100ps Printer
Hp designjet 800 ps plus system error severe errora: 0x8010003 task: tmech file: sequence.c line: 636
Notate the error and put it in a search. Since it appears to be a server error, remove then reinstall the driver software.
Jul 09, 2011 | HP DesignJet 500 InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
The problem is even we already replace the printheads with the new ones, the plotter still shows error message : replace 20 status. is there any way to solve this uncommon problems ?
When false "replace print head" messages occur, it is almost always a bad trailing cable. They are a little tricky to replace but if you want the manual to see how to do it, download it here: www.lpscomputer.com/ec/manuals.htm
The part is available here: http://www.lpscomputer.com/p-2296-c6074-60418-designjet-1050c-1055cm-trailing-cable.aspx
Jan 05, 2010 | HP DesignJet 1050c InkJet Printer
Error on display
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
Hp designjet 430
This usually is solved by removing and reinstalling the ink cartridges...make sure the electrical contacts are clean (use a dry paper towel) on both the print cartridge and the carriage.
If the error still happens then the carriage or trailing cable are bad and will need replaced.
Nov 28, 2007 | HP DesignJet 430 InkJet Printer
HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB 10/100 GL/2 HD- W/ LEGS C7780BABA HPHEWLETTPACKARD Printer Logo
534 people viewed this question
Seeker5211
Seeker5211
