Question about EnterTech Enter Tech Magic Sing Mic Karaoke Leadsinger Song Chip
Nand id:err in my magic mic ... when i turned it on only the vertical 4 colors was the display
Model ed-2000
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
Why is there no power on the mic?
try putting fresh batteries, but disconnecting the ac adapter temporarily. If power is intermittent, the power button could be internally dirty. I normally open it up to clean the plastic buttons.
Mar 29, 2016 | Magic Entertech ED-9000 Mic Sing Along...
How to use radio controls after code set
if you have the code (you say you do) turn radio on, push the code, radio should come on automatically (here is my code it will work on yours 2145) so 1 turn radio on. err code will show dont worry about it. 2. punch in 4 digit code.3. complete code will flash 3 times. 4. radio will be fully functional, use as normal. if you enter code wrong an Err will display for a few sec. COde will then display. repeat procedure 1-3.
Apr 20, 2013 | 2000 Daewoo Nubira
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I am getting an err message on display, when i try to insert a cd in the 4 disc changer in my 2000 dodge intrepid???
it is bad you need to go to your nearest junkyard and get a used one. had many go bad on stratus,sebrings,intrepids,neon they all take the same one in 2000 all the way to 2005 or 2006
May 24, 2009 | 2000 Dodge Intrepid
ED-9000 freezes
try removing the song chip( if your using one)
test the mic with its built in songs...
if it works- then the problem is on the song chip- try cleaning it......
customerservice@magicmic.com
Jan 01, 2009 | Magic Sing Along Consumer Microphone
Oh no
was this playstations update or a 2nd party update?
if sony
contact sony for a replacement.
if secound party
http://dl.qj.net/General-IdStorage-Repair-...13178/catid/114
there is some downgrade tools there.
you can buy a mod chip and install it
you can buy a new motherboard
Youve at least corrupted your nand.
So you will need a pandora battery and a magic memory stick with a non corrupt nand for 3.90m33-2 (if you have a slim, then you must use a slims nand, fat must use fat).
put in the mem stick
put in the batt
click whatever button you need to to restore nand
turn it back on, if you have the BSOD, then you have corrupted your id storage keys.
If by some chance you used a key cleaner previously, then you have a copy of your specific storage keys.
You can reinstall them using the same method as the nand
if you dont have a backup of the id storage, you have to buy a new motherboard as the mod chip will not fix it
Aug 01, 2008 | Sony PlayStation Portable (PSP) Console
ED 9000 picture problem
I hope you have configured the MIC for NTSC. By default it comes configured for PAL (Indian TV standard). The manual explains how to do it.
Feb 23, 2008 | Magic Entertech ED-9000 Mic Sing Along...
Entertech mic ed-9000--Mic stopped working
Could be the wiring in the RCA cable.
Swinging mike to and fro can wear through the power wiring inside the cable.
I'm on my 3rd cable.
Manufacturers have said they recognise this is a common fault with product but it seems they are not taking any steps to rectify.
I found that using the mike with batteries sometimes works.
If you get a new cable may be a good idea to reinforce the top 12 - 18 inches of the cable to avoid same problem in future.
Nov 16, 2007 | Magic (ED8000) Professional Microphone
EnterTech Enter Tech Magic Sing Mic Karaoke Leadsinger Song Chip Logo
48 people viewed this question
Top EnterTech Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an EnterTech Toy Expert? Answer questions, earn points and help others
